I’m using deconz with a conbee 2 and some temperature and humidity sensors.
I would like to add some plugs, and a outdoor light sensor.
(i need to have a plug who act as a zigbee repeater, i’m not sur they do it all ?)
For people who have the same config, which one do you use ?
The idea is to be sure to buy something compatible.
Does the sensor provide a light level and is it accurate?
If OP only wants a light sensor, then I’d say the Philips motion sensor is overkill (and overpriced :))
Does the plug act well as a repeater, from what I heard they don’t route well.
hi, could you say me if the motion sensor can act like a switch even if there is no motion detected ?
For exemple, using it with the zone and activate the some light when your smartphone is in the zone (even if you are not in the motion detect range) … but also using it like a normal motion sensor ?
The motion sensor is separate from the light, they are not connected to each other. The lights are turned on by an automation when motion is detected, but you can also turn on the light at a specific time, or when you are in a zone or whatever. However, you need either a smart light bulb or a smart light switch for this to work.
I never heard or saw any out-of-the-box device that does this AND can be connected to HA, DIY should be possible. Can you not make the light “smart” with a switch or bulb?
There are some behind the wall switches that can also connect a legacy switch. Most of them are rebranded/cloned(?) Sunricher devices. Mine works just fine with the conbee2 (using OpenZHA, not deconz).
However, as far as I have read, the connected switch does not make the device announce its new state via Zigbee, which makes it kind of uninteresting imho.
I keep hearing this but I don’t know if it’s true. I can personally say that I have Xiaomi lux sensors, multi sensors and window sensors. They all have no trouble at all with my IKEA bulbs or repeaters accessing my ConBee II
