I was wondering whether there is an add-on/plugin to monitor sensors and to get a notification when one of the monitored sensors isn’t sending information for a certain period.
Ofcourse I could write my own automation, however I am not the only one facing these problems, so that’s why I would like to know this!
Thanks in advance!
Two options:
This sensor lists any devices in a group that are reported as unknown:
sensors:
offline_devices:
friendly_name: "Offline Devices"
value_template: >
{{ expand(states.group.watchdog_devices.attributes.entity_id|list) | selectattr('state', 'in', ['unavailable', 'unknown', 'none']) | map(attribute='entity_id') | list | length }}
entity_id: sensor.time
attribute_templates:
entities: >
{{ expand(states.group.watchdog_devices.attributes.entity_id|list) | selectattr('state', 'in', ['unavailable', 'unknown', 'none']) | map(attribute='entity_id') | list | join('\n') }}
Just create and populate the group “watchdog_devices” with whatever you want to track.
The other option I use is a script / automation that reports if a device hasn’t changed its value in a configurable amount of time:
script:
watchdog:
alias: 'Entity Watchdog'
# description: "Entity Watchdog"
# fields:
# entity_id:
# description: 'The entity to check'
# example: 'binary_sensor.sensor'
# time:
# description: 'The max number of seconds before an alert'
# example: '300'
sequence:
- service: persistent_notification.dismiss
data_template:
notification_id: 'Watchdog:{{entity_id}}'
- condition: template
value_template: '{{ ( now()|as_timestamp() - states[entity_id].last_updated|default(0,true)|as_timestamp()|default(0,true) ) > time }}'
- service: persistent_notification.create
data_template:
title: 'Watchdog: {{ entity_id }}'
message: >
{%- if states[entity_id].last_updated %}
Entity {{ entity_id }} has not been updated in {{ ( now()|as_timestamp() - states[entity_id].last_updated|default(0,true)|as_timestamp()|default(0,true) )|int }}
seconds which is longer than the max allowed of {{ time }}.
{%- else %}
Entity {{ entity_id }} does not seem to exist.
{%- endif %}
To use the script, I have an automation that runs every 5 minutes and checks each device I want to watch:
automation:
- alias: Watchdog
platform: time_pattern
minutes: "/5"
- service: script.watchdog
entity_id: sensor.living_room_51_10
time: 600
entity_id: sensor.kitchen_52_10
time: 1200
(Extend the action section to include as many devices as you want to check.
Hope this helps.
Thanks!! That’s what I was looking for.
Would there also be the possibility to add a notification to the script when the sensor changed its value after being unresponsive?
The second option which uses the script & automation creates a persistent notification if a device is unresponsive. If the device later responds, it automatically removes the persistent notification.
