Plugin Samsung smart TV
Good morning everyone.
I’m using the ha-samsungtv-smart plugin: GitHub - ollo69/ha-samsungtv-smart: 📺 Home Assistant SamsungTV Smart Component with simplified SmartThings API Support configurable from User Interface.
which is great for selecting sources, performing actions, or launching services, and frankly, I haven’t found anything better.
My problem is that I unfortunately deleted my Smartthings token, which I created before the (so stupid) Smartthings restriction, which since January 2025 has deactivated the token after 24 hours. As it stands, I’m forced to regenerate a token every 24 hours, which is completely absurd. Furthermore, the plugin’s development team no longer maintains it, which means it won’t migrate to OAuth 2.0 for a permanent connection to Smartthings.
Do you know of a fork of this plugin or another plugin (that compensates for token expiration) that can achieve the same usage?
Thanks in advance.
