Plugins for Geo’s Waterlock
I have a Geo Waterlock system to stop leak damage to my flat. The waterlock system has a series of sensors that are supposed to detect leaks and then shot the water main. The system works with hub that probably uses Z-Wave system to comunícate with the water valve and the sensors. The sensors apart from detecting liquid water also send back info about air humidity and temperature to the hub. The stem is supposed to work automatically. However, all this info is also sent to an App on your phone.It would be ideal if it could also be integrated into Home Assistant but at the moment it has no integration with any home automation system.
Is there anyone in the community that could develop a plugin for it?
