Plugwise (Anna) breaking changes
Since 2024.12 the Smile / Anna climate doesn’t work anymore!
  1. The history doesn’t show the heating anymore (see picture)
  2. The presets aren’t recognised anymore but setting temp works (away / sleep / etd)
Please help / fix!
That’s strange, no changes for Anna in 2024.12 (I’m a Plugwise Integration-owner).
What does your binary_sensor Opentherm Heating show?
I have an Adam + Anna, it works for me:
I have something similar:
The status is the default Plugwise Anna panel does not update correctly.
The binary_sensor.onoff_heating entity is updating correctly, the status in
the entity: climate.anna does not get updates, see attached picture.
I use the Plugwise Anna in on/off, not with OpenTherm
Any help greatly appreciated!
Maurijn
There are more users having this problem: Climate-card and climate-entity not showing the correct HVAC_Action state · Issue #132935 · home-assistant/core · GitHub
Also, looks like other thermostat-brands experience the same problem.
Thank you for looking into this, Bouwe.
Maybe dumb questions from a newby:
Are the possible states in the card only idle and heating?
If yes, can’t the card just use the binary_sensor.onoff_heating entity?
That one is showing the correct state.
Thanks again,
Maurijn
Yes, the state of the climate-card is based on the hvac_action attribute of the connected climate-entity. For an Anna there are indeed two options: idle and heating.
And, yes, these hvac_action-states are based on the state of the binary_sensor.onoff_heating.
So the Plugwise integration (still) does what it needs to do. It appears something in HA that sits between the integration and the climate-entity and climate-card has recently become broken.
