I am running HA Core 2021.8.0 on a Ubuntu 20.04 LTS virtual system.
I have a Plugwise P1 powermeter reader to load elektric and gas usage data into HA.
This works well as an integration in a card.
Now with this new energy module in 2021.8.0 i tried to add the plugwise p1 as consumption source but it says:“No matching stats found”.
Maybe the plugwise doesn’t work with this energie module or something is wrong with the integration?
Or i am doing something wrong?
The HA gui suggets you inform the Plugwise integration developers about this issue, since they probably missed this : Sensor Entity | Home Assistant Developer Docs
We just need to find out WHO
As a work around, I tried the Utility Meter integration, and that works pretty good, so far
after configuring that make sure, the entities you created, have these values in their yaml :
state_class: measurement
unit_of_measurement: kWh
device_class: energy
(use this menu for these settings: http://homeassistant:8123/developer-tools/state)
