Been trying to figure out if the Plugwise Lisa would work standalone (via either my conbee2 or zigbee2mqtt stick). All i see references the adam module (which is the base?)
I would have a OT mqtt controller already setup so i just need to get the temperature and setpoint from Lisa. And if possible send back the status (like heating is active and such)
Why do you want to use a Lisa for that? I’m not completely sure but I think the setpoint is managed on the Adam, the Lisa just passes the changes along.
You should be able to achieve the same result with a simple temperature sensor and do the scheduling in an integration or a custom_component?
Had the same idea to use Lisa as standalone. I tried it, but I’m not able to access the set temperature and other functions. I’m only able to read the current temperature. Anyone get any further with this?
