PLZ help me about local file
PLZ help me… i can’t solve this problem for a week…
i donlt know what;s the problem… wrong code? what;s wrong code?
plz help me…
each configuration.yaml, automations.yaml and scripts.yaml.
my device is ESP32-cam and i add esphome. nodename is espcam1
i want to save snapshot file in my /config/www/images/
this is error log
homeassistant:
  # HA접속시 표시되는 이름
  #whitelist_external_dirs:
   #- /config/www/images
# Example configuration.yaml entry
camera:
  - platform: local_file
    file_path: /config/www/images/cam_snapshot.jpg
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:  #이거 없애면 큰일난다. 404 에러 바로 뜬다.
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
#   base_url: example.duckdns.org:8123
# Text to speech
tts:
  - platform: google_translate
#group: !include groups.yaml
#automation: !include automations.yaml
#script: !include scripts.yaml
#scene: !include scenes.yaml
configration.yaml
- alias: last motion time
  initial_state: 'on'
    platform: state
    entity_id: binary_sensor.motion
    to: 'on'
    - service: input_datetime.set_datetime
      data_template:
        entity_id: input_datetime.last_motion_time
        time: '{{ (as_timestamp(now()) | timestamp_custom("%H:%M:%S", true)) }}'
    - service: script.snapshot_cam1
      #- service: camera.snapshot
        #data:
          #entity_id: camera.espcam1
          #filename: /config/www/images/espcam1_{{ now().strftime("%Y%m%d-%H%M%S")}}
automations.yaml
snapshot_cam1:
  sequence:
  - condition: state
    state: 'idle'
      filename: /config/www/images/cam_snapshot.jpg
  - delay: 5
    data_template:
      filename: /config/www/images/cam_snapshot_{{ now().strftime("%Y%m%d-%H%M%S") }}.jpg
scripts.yaml
plz help me thank a lot
I don’t know enough to be sure that what I think might be errors actually are errors, and I don’t want to mislead you! However if this was my config I’d check that cam_snapshot.jpg actually exists in /config/www/images/ .
thank you for your advice…
So… make cam_
snapshot.jpg in /config/www/images passively??
like this? thank you
Is that an actual file ?
It says it has zero size ???
So you are complaining that your system can not read an image file (placed there by a camera snapshot) and you are testing this by faking it with a text file placed manually ?
No what I was suggesting that your ESP32 Cam is supposed to save the image file in /config/www/images/ If it is not saving the file there,then that is at least one reason why you are getting the error message that it cannot read the file.Once we know the image is actually there it’s a case of working out why the automation etc. isn’t working.
yes… is there any wrong code? if i make fake file cam_snapshot.jpg there was no error log in homeassistant.
So… you said i should write code about /config/www/images/ in .yaml ?
Use an actual jpg file not a txt file to test it. Any photo will do.
The error specifically says it can’t open the file. Because it is expecting an image file and you put a text file there with an altered extension.
I’m not saying you should write anything :slight_smile: as other people have suggested, put an actual jpg in /config/www/images/ and rename it so that it’s called cam_snapshot.jpg then see if it works.
THanks a lot… i solved this problem… made actual .jpg file thank a lot
