I have been using triggers based on amount of solar generated to run my pool filter and it’s worked for the better part of the year. The past few weeks the turn off filter part in particular, has stopped working.
It should have monitor for solar generated if its above 2500 for 5 minutes, turn the filter on and if it drops below for 5 minutes then turn it off.
What have i done wrong?
alias: Solar Panel - Control Pool Pump
description: Based on solar generation, turn the pool pump on or off
- platform: numeric_state
entity_id:
- sensor.primo_8_2_1_1_power_ac
for:
hours: 0
minutes: 5
seconds: 0
above: 2500
entity_id:
for:
hours: 0
minutes: 5
seconds: 0
id: "Solar low "
below: 2500
condition:
- condition: time
before: "18:30:00"
after: "06:00:00"
weekday:
- sat
- fri
- thu
- wed
- tue
- mon
- sun
- if:
- condition: trigger
id:
- Solar high
- "Solar low "
then:
- type: turn_on
device_id: 8554a818ce8999abaf4a5f1f42ec43ca
entity_id: light.hue_color_light_2_3
domain: light
- service: notify.persistent_notification
title: Alert - Solar Generation
message: High Solar, Turning on Pool Pump
- type: turn_on
device_id: c0a28df2742abca3d17b20375d3e8480
entity_id: switch.bat_plug_pool
domain: switch
else:
- type: turn_off
domain: light
message: Low Solar, Turning off Pool Pump
- type: turn_off
domain: switch
mode: single
