ozzi91
(ozzi91)
April 20, 2019, 11:34pm
1
Hello!
I bought a sensor PMS7003, used config from: https://esphome.io/components/sensor/pmsx003.html?highlight=particulate and it is working perfectly but I would like to extend a lifetime of this sensor by extend interval time. Now it is a few seconds. I just want to use it as: https://esphome.io/components/sensor/sds011.html there is a update interval option. Is it possible to add soon?
Is there a way to disable blinking blue led on wemos d1 mini when u use uart? @OttoWinter
jure.mav
(Jure Mav)
May 22, 2019, 8:14pm
2
This would would be great feature
glmnet
(Guillermo Ruffino)
May 22, 2019, 8:53pm
3
you better fill an issue or a feature request
jblb
(Jb Lb)
May 24, 2019, 7:45am
5
@ozzi91 just go here https://github.com/esphome/feature-requests and open a new issue. If you don’t know how to i can do it for you.
ozzi91
(ozzi91)
May 25, 2019, 8:31pm
6
Yee i dont know, github is not friendly for me at all.
I fu can do it for me, i will be gratefull
jblb
(Jb Lb)
June 4, 2019, 8:00am
7
Hi @ozzi91
I open a feature-request
https://github.com/esphome/feature-requests/issues/269
i let you see OttoWinter answser
ozzi91
(ozzi91)
June 5, 2019, 6:24pm
8
Thank you, im writing a answer right now
ozzi91
(ozzi91)
June 8, 2019, 5:48pm
9
Mby u would “translate” it to simpler words so i can make it work?
mac587
(Mac587)
October 27, 2019, 1:24pm
10
Datasheet for pms5003/7003 state a mean time between failure of ≥3 years, or 26280 hours.
Datasheet for the nova sds011 does state an 8000 hour laser life.
I would have thought the lifetime would be similar to that of an led, perhaps dust inside the sds011 is a contributing factor
If anyone can give me any pointers with wiring a pms7003 that would be tops… See here. Ta.
Hey @jbwiden I am about to try to hook up my 7003 to an esp32 with esphome.
I’m a bit confused about how to wire it up and configure it.
I didn’t find many resources around.
Do you have any links, photos, config you can share?
Would also like to copy your sleep idea.
Cheers. [16263445360606787235929952960636]
Edit: All good got it… Pmsx003 Air quality sensor longevity and data stability - #5 by Mahko_Mahko
