Poblem with google mini and tts
Hello guys,
I have buy a Google Home mini, and just working fine, but by text to speek don’t work…
Do not transmit the tts (mp3) just make the beep.
http:
  api_password: !secret http_password
  base_url: xxxxx.duckdns.org:8123
  ssl_certificate: /ssl/fullchain.pem
  ssl_key: /ssl/privkey.pem
tts:
  - platform: google
    cache: true
    cache_dir: /config/tts
    time_memory: 300
    language: 'it'
i open the port of my nat 443->8123
Chromcast radio working fine
Any ideas?
any help?
For mine, my base_url is xxxx.duckdns.org - without the port part.
try updating your configuration.yaml to remove the port part of base_url and try it again (after restarting homeassistant.
Did you ever fix this? I’m having the same problem…
I’m having trouble with chrome cast Audio but my google home works fine.
