Podlewanie is a garden irrigation controller configured entirely from the UI. It replaces the usual stack of Irrigation Unlimited, Smart Irrigation and a pile of automations with one integration, and drives valves you already have (any switch.* or valve.* entity), so LinkTap, Rainbird, Zigbee valves and relays all work.
What you get
- Zones, each with its own valve, area, default and maximum run time
- Schedules (time, months, weekdays) that start a sequential run of all enabled zones
- Hargreaves ET0 calculated daily at 03:00 from your Home Assistant latitude and the daily temperature range (min/max come from the forecast of the weather entity you pick)
- Per-zone moisture bucket that tracks water lost and applied, with optional soil moisture correction
- Rain skipping (rain sensors, a rain binary sensor, forecast entity)
- Anti-freeze flush with temperature tiers
- Optional rainwater tank pump controller with level hysteresis
- State survives restarts (bucket levels, enabled flags, adjustments); one HA device per zone
- Six services:
manual_run,run_sequence,cancel,adjust_time,enable,disable
Install
HACS, Custom repositories, add GitHub - jrx-code/hassio-integration-podlewanie: Garden irrigation controller for Home Assistant: zones, schedules, Hargreaves ET0 water budget, rain skip, anti-freeze, rainwater tank pump. UI config only. · GitHub as an Integration, download, restart, then Settings, Devices & services, Add integration, Podlewanie. Zones, schedules, weather, tank and anti-freeze are all set under Configure; no YAML. An older v1 YAML configuration is imported automatically.
Status
Version 2.0.1, MIT licensed, hassfest and HACS validation run in CI. Written for and used on one garden with four zones, so other setups may hit gaps. Needs Home Assistant 2024.6 or newer. Bug reports and feature requests are welcome on GitHub.
