I am looking to install POE switch for 12 cameras in garage and connect it to POE surveillance cameras. I am worry about summer heat as it can hit up to 120F outside which means it can get pretty hot in garage. Any recommendation on what POE switch I should buy?
I use one of these. Works perfectly. Manual says it’s good to 131F
@Vlad Do consider the NVR options from your camera maker. At times, their sans-HDD cost is almost the same as a POE switch.
It’s not that i do not want to use NVR, it’s the fact i can’t get wiring to NVR directly. For that reason i need to set up POE switch and plug in network cable which i can plug in to my network.
