Poll Aeotec MultiSensor 6 luminocity when light turns off
I have a setup in which after 30 secs of no movement detection the light turns off. I onlz want it to turn off if the luminocity is less than 4 but in its current setup it doesnt work, because it uses the luminocity value when the light was on. Is there any way i can trigger o polling of the luminocity as soon as the light goes off?
Assuming it’s mains powered, drop setting 43: Luminance Reporting Threshold to one. That’ll result in an update when the light level changes by one, which should be sufficient.
