Pollen Count/ Allergy tracker UK
Hi all
this topic has been around before, but i cannot find any integrations for the UK.
I would really like to have pollen count and flu information displayed on our Lovelace UI. we all suffer in this house, so would be a nice on for us to have on the front page. something similar to this, found on a different post, but uses the API from pollen.com which does not cover the UK.
I would need to add that I am still quite new to HA (and any coding) so would need a little help to get this set up.
I have managed to set up the Met Office sensors and can get this into Lovelace, but they do not have any pollen count info. The BBC weather do have pollen, and an RSS feed, could this be used? also seems they do a REST, see link for more info https://support.bbc.co.uk/platform/feeds/WeatherFeeds.htm
Assuming that I could use the REST(sensor?) or RSS how would I be able to display this in Lovelace?
Sorry to have so many questions here, but it is a bit baffling how to get this info into HA and to be able to display it. Very happy for it to be nice and simple as the above image.
TIA
Andy
For anyone who stumbles across this old post (like I did), here is a solution -
I gave this a go today and have no faith in tomorrow.io. I configured the location to be my home address and get the following for pollen:
A quick check against MetOffice shows the following:
This is such a shame. I so wanted this integration to work being a really bad Hayfever sufferer :cry:
Hi everyone!
If you’re looking for a way to track pollen, my integration might be just what you need. I built this integration primarily for myself, and it creates a sensor for the general evaluation of pollen levels—the SILAM Pollen Index (Very Low, Low, Moderate, High, Very High)—along with separate sensors for each pollen type. The sensors display the modeled number of pollen grains per cubic meter, with data pulled from the SILAM Pollen website.
You can find more details in this post: SILAM Pollen Allergy Sensor Integration for HA and on the GitHub repository.
