Hi all,
Looking for some help trying to make a pollen count but the API i’m using requires square brackets in the config see below
sensor pollen:
and its reporting back blank, any ideas
Location changed
have you tried putting ‘single’ or “double” quotes around the URL?
Yeah i’ve tried single double and none but it always outputs a blank reply in home assistant
Have you tried putting a backslash () before both the open and close brackets (e.g. resource: https://socialpollencount.co.uk/api/forecast?location=[51.7556407,-1.25157468])?
arsaboo
(Arsaboo)
5
You need to use {{ value_json.forecast[0].pollen_count}}
(adjust the number based on the date). So your sensor would look like:
- platform: rest
resource: 'https://socialpollencount.co.uk/api/forecast?location=[51.7556407,-1.25157466]'
value_template: '{{ value_json.forecast[0].pollen_count}}'
Thanks ive tried the suggested / but no joy
Awesome, that looks to be returning the correct value
Thanks @arsaboo
uiguy
9
Looks like this is busted again. Can someone confirm?
uiguy
10
Log Details (ERROR)
Thu Sep 27 2018 15:28:03 GMT+0100 (British Summer Time)
Error parsing value: list object has no element 1 (value: {"status_code":"200 OK","date":"2018-09-27T14:29:03+00:00","forecast":[]}, template: {{ value_json.forecast[1].pollen_count}})
uiguy
12
Just un-#'d mine and it seems to be working now again…
