Polling API for new devices
So for context, I want to make an integration that relies on polling an API. This API endpoint only returns the devices if they are physically turned on.
I made use of the following code from Fetching Data | Home Assistant Developer Docs.
"""Example integration using DataUpdateCoordinator."""
from datetime import timedelta
import logging
import async_timeout
from homeassistant.components.light import LightEntity
from homeassistant.exceptions import ConfigEntryAuthFailed
from homeassistant.helpers.update_coordinator import (
    CoordinatorEntity,
    DataUpdateCoordinator,
    UpdateFailed,
from .const import DOMAIN
_LOGGER = logging.getLogger(__name__)
async def async_setup_entry(hass, entry, async_add_entities):
    """Config entry example."""
    # assuming API object stored here by __init__.py
    api = hass.data[DOMAIN][entry.entry_id]
    async def async_update_data():
        """Fetch data from API endpoint.
        This is the place to pre-process the data to lookup tables
        so entities can quickly look up their data.
        try:
            # Note: asyncio.TimeoutError and aiohttp.ClientError are already
            # handled by the data update coordinator.
            async with async_timeout.timeout(10):
                return await api.fetch_data()
        except ApiAuthError as err:
            # Raising ConfigEntryAuthFailed will cancel future updates
            # and start a config flow with SOURCE_REAUTH (async_step_reauth)
            raise ConfigEntryAuthFailed from err
        except ApiError as err:
            raise UpdateFailed(f"Error communicating with API: {err}")
    coordinator = DataUpdateCoordinator(
        hass,
        _LOGGER,
        # Name of the data. For logging purposes.
        name="sensor",
        update_method=async_update_data,
        # Polling interval. Will only be polled if there are subscribers.
        update_interval=timedelta(seconds=30),
    # Fetch initial data so we have data when entities subscribe
    # If the refresh fails, async_config_entry_first_refresh will
    # raise ConfigEntryNotReady and setup will try again later
    # If you do not want to retry setup on failure, use
    # coordinator.async_refresh() instead
    await coordinator.async_config_entry_first_refresh()
    async_add_entities(
        MyEntity(coordinator, idx) for idx, ent in enumerate(coordinator.data)
class MyEntity(CoordinatorEntity, LightEntity):
    """An entity using CoordinatorEntity.
    The CoordinatorEntity class provides:
      should_poll
      async_update
      async_added_to_hass
      available
    def __init__(self, coordinator, idx):
        """Pass coordinator to CoordinatorEntity."""
        super().__init__(coordinator)
        self.idx = idx
    @property
    def is_on(self):
        """Return entity state.
        Example to show how we fetch data from coordinator.
        self.coordinator.data[self.idx]["state"]
    async def async_turn_on(self, **kwargs):
        """Turn the light on.
        Example method how to request data updates.
        # Do the turning on.
        # Update the data
        await self.coordinator.async_request_refresh()
However, this example will only poll when there are subscribers (registered entities). So when I start HA and my API does not return any device, the polling won’t start.
How would I go about changing this example code to poll always? Even when there is no device returned from the API.
I am not sure if you can add new devices without reloading your integration. At init (__init__), you set up your platforms and add your entites under platform setup (async_setup_entry). Maybe, you can keep a reference to async_add_devices function and use it later on when you want to define a new entity.
