Polling multiple MiFlora modules with multiple ESP32 Modules
Here’s a simplified version of what I’m trying solve:
Let’s say I have a single MiFlora module set with a houseplant.
My wife likes to move the houseplant around the house, beyond the range of a single esp32 device (polled via esphome). I have placed an ESP32 on each floor to accommodate for this.
So I now have at least one of the ESP32s that can read the MiFlora device, but I also have 3 separate sensors for that MiFlora device - one for each of the ESP32 devices.
Am I missing some easy way to address this? If not, I’m thinking that I’ll go with a Template sensor and take a max value (or some variation).
Thanks!
Yeas, each ESP will create a sensor, so you will have to combine them with a template sensor. Using the max value is one way if you use the float filter on the sensors, as this will return the unavailable state as 0.
So:
value_template: "{{ [states('sensor.esp1') | float, states('sensor.esp2') | float, states('sensor.esp3') | float] | max }}"
Thank you, @tom_l.
I had tried the Max value without the float, found it didn’t work, came back here and the working solution was waiting.
Thanks much!
