I’ve noticed something that would indicate the documentation is not correct on zwave polling.
I have polling interval set to 60000 and intensity for the devices set to 1.
But in my OZW logs I see clearly that only ONE device is polled per cycle; so in this case 1 device a minute. See below.
It clearly shows one device being polled per interval of 60s.
Anyone else see this? If so it would suggest that polling interval can be significantly dropped as polling once device per second would not be extreme.
2017-09-18 08:28:04.472 Detail, Node004, Polling: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 08:29:04.513 Detail, Node005, Polling: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 08:30:04.555 Detail, Node006, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 08:31:04.676 Detail, Node007, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 08:32:04.717 Detail, Node008, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 08:33:04.758 Detail, Node011, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 08:34:04.799 Detail, Node012, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 08:35:04.840 Detail, Node014, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 08:36:04.995 Detail, Node015, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 08:37:05.036 Detail, Node016, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 08:38:05.077 Detail, Node017, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 08:39:05.118 Detail, Node018, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 08:40:05.160 Detail, Node019, Polling: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 08:41:05.261 Detail, Node021, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 08:42:05.302 Detail, Node022, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 08:43:05.343 Detail, Node023, Polling: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 08:44:05.385 Detail, Node025, Polling: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 08:46:17.445 Detail, Node027, Polling: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 08:47:17.547 Detail, Node028, Polling: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 08:48:17.588 Detail, Node058, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 08:49:17.689 Detail, Node068, Polling: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 08:50:17.730 Detail, Node070, Polling: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 08:51:17.771 Detail, Node004, Polling: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 08:52:17.812 Detail, Node005, Polling: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 08:53:17.853 Detail, Node006, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 08:54:17.989 Detail, Node007, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 08:55:18.030 Detail, Node008, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 08:56:18.071 Detail, Node011, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 08:57:18.112 Detail, Node012, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 08:58:18.153 Detail, Node014, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 08:59:18.224 Detail, Node015, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:00:18.265 Detail, Node016, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:01:18.307 Detail, Node017, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:02:18.348 Detail, Node018, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:03:18.389 Detail, Node019, Polling: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:04:18.490 Detail, Node021, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:05:18.531 Detail, Node022, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:06:18.572 Detail, Node023, Polling: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:07:18.614 Detail, Node025, Polling: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:08:18.655 Detail, Node027, Polling: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:09:18.756 Detail, Node028, Polling: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:10:18.797 Detail, Node058, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:11:18.899 Detail, Node068, Polling: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:12:18.940 Detail, Node070, Polling: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:13:18.981 Detail, Node004, Polling: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:14:19.022 Detail, Node005, Polling: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:15:19.063 Detail, Node006, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:16:19.187 Detail, Node007, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:17:19.228 Detail, Node008, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:18:38.352 Detail, Node011, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:19:38.393 Detail, Node012, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:20:38.435 Detail, Node014, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:21:38.476 Detail, Node015, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:22:38.518 Detail, Node016, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:23:38.559 Detail, Node017, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:24:38.600 Detail, Node018, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:25:38.641 Detail, Node019, Polling: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:26:38.742 Detail, Node021, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:27:38.784 Detail, Node022, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:28:38.825 Detail, Node023, Polling: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:29:38.866 Detail, Node025, Polling: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:30:38.907 Detail, Node027, Polling: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:31:39.008 Detail, Node028, Polling: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:32:39.049 Detail, Node058, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:33:39.150 Detail, Node068, Polling: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:34:39.191 Detail, Node070, Polling: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:35:39.233 Detail, Node004, Polling: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (poll queue has 0 messages)
2017-09-18 09:36:39.274 Detail, Node005, Polling: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (poll queue has 0 messages)
