I’m creating a custom component to integrate an alarm platform.
I can query the alarm system via tcp/ip to get the status of the the different sensors
import socket
import time
import binascii
try:
client = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
except socket.error:
print('Failed to create socket')
E_IP= "192.168.0.4"
E_PORT = 10002
client.connect((E_IP,E_PORT))
payload = bytes.fromhex( "02010800003f004803")
try:
client.send(payload)
msg = client.recv(4096)
print('Failed to send data')
client.close()
The component will need to poll the alarm system every 0.5 sec / 1sec.
What’s the best method to implement it? Can you point me to an existing component that is using this mechanism?
Thanks!
