Polygonal zones
Hey all,
I was looking into how to create polyogonal zones. Found some discussions about it and a couple of examples in node-red. I even found a proposal to integrate it into hass core. while waiting for a bit to see if there was any traction for it i decided to create a custom integration for it.
Enter my first integration, Polygonal zones. It is lacking in a large amount of features but it supplies a way to configure from the ui and the ability to easely store multiple zones.
The current version makes use of GeoJSON to store the zone information and shapely to check in which zone you are. there are a large amount of improvements that can still be made. The current version is a proof of concept i hope you guys can help me test.
Installing/Configuring the integration
installing the integration is as simple as copying the custom_components/polygonal_zones folder into your config/custom_components folder and following the configuration flow.
However before following the integration flow you need to create a geojson file accessible for a homeassistant via the web. the easiest place i found is to just place it into your config/www folder. once you have done that you can simple configure the integration via the ui. the first field is for the url of the GeoJSON file and the second is the entities to track.
How it works
Once you have the integration configured it will create a sensor for each entity you selected. it will update this every time the location or accuracy of the tracked device changes.
What makes it different
Not much differentiates it form the different implementations there are but the biggest difference i can find is that it takes into account the accuracy of the gps signal. all other options i found just check the latitude and longitude. however that didnt work for me as i was using some realy inprecise gps trackers. besides that it isnt implemented in node red and is actualy functional
Limitations / TODO
There are still a large amount of things to improve. the biggest limitation currently is you cant track a single entity multiple times. besides that there are not tests for the code. also it might not work on armhf as i heard that shapely doesn’t support it(current is only tested on a intel nuc).
If you are interested in this please dont just use this but contribute to the discussion/proposal to get it integrated into core Allow zone to be a polygon · home-assistant/architecture · Discussion #1014 · GitHub. if you want to improve this my integration feel free to open a pr/issue.
@MichelGerding Great idea for polygonal zones, love to have this implemented.
Trying to test the integration with some google map device_tracker entities.
I created and saved the GeoJSON file using geojson.io as map.geojson in config/www folder.
Configuration of Polygon Zones integration went fine without error but the entity created had unknown state.
Reloading the integration showed ‘Failed to set up’, log had this:
2024-09-03 22:20:22.726 ERROR (MainThread) [homeassistant.components.sensor] Error adding entity sensor.polygonal_zone_tracker_device_tracker_google_maps_[device name] for domain sensor with platform polygonal_zones
File “/srv/homeassistant/lib/python3.12/site-packages/homeassistant/helpers/entity_platform.py”, line 912, in _async_add_entity
await entity.add_to_platform_finish()
File “/srv/homeassistant/lib/python3.12/site-packages/homeassistant/helpers/entity.py”, line 1365, in add_to_platform_finish
await self.async_added_to_hass()
File “/home/homeassistant/.homeassistant/custom_components/polygonal_zones/sensor.py”, line 91, in async_added_to_hass
self._zones = self.hass.data[DOMAIN][self._config_entry_id][DATA_ZONES]
TypeError: ‘ConfigEntry’ object is not subscriptable
Would you please help figure out what’s going on?
TIA
Hey thanks for trying it out. and im sorry for the late response was away from my pc for the last bit.
it should be fixed in the latest version. Something had gone wrong with the latest push. the current version is wat i am currently using on my instance. the interface is not responsive at all but should be easier to edit. it can be found in this repo
if there are any other problems let me know and i will try to fix them as quicly as i can
I also managed to make a simple addon that you can use to host and create the zones.json file.
So you have moved from a custom_component to an addon? Confusing!
I have added a addon. The custom component is still the same but added a addon in which you can edit the zones.
Happy to say: both pieces work perfectly for me!
Hi!
I am really happy about your addon and I followed since longer the discussion / proposal as well.
It depends strongly on the specific geo conditions if u need polygons or just circles.
In my case were circles absolutely not useful and were causing a mess with arriving / leaving the geofence.
Anyway, I installed your addon today quite quick without any issues and it works till now perfectly.
I will check it out some days and will replace the home zone with the created polygon.
Its for me a must have to adjust the geofencing in a proper way.
This is just what I’ve been looking for. I never get why a radius is accepted as good enough for a zone. I will install and check it out, but am already wondering if this is still an active project? I think a lot of people would see the usefulness of polygonal (true geofencing) zones if they only knew that is a thing. So maybe some visibility is needed somehow.
Finally!
I have wished for something like this ever since the introduction of zones in Home Assistant.
I will install this today and give it a go :smiley:
I have followed the installation instructions on your GitHub but i can’t get it to work. I have added the integration and the Add on and then added some zones. After that i have added my phone as a device_tracker in the integration but but it’s status is always away. Can not get it to register that i’m in any of the zones. And ideas?
I just came across this topic while doing a general search for polygon zones. I’ve also thought about how to implement them. I actually programed all the basic algorithms required over 30 years ago in autolisp for autocad. Anyway, I just ported all my pertinent lisp functions over to jinja and now have a working proof of concept of incorporating multiple polygon zones with all the computations done in jinja with generic functions defined in and set up to use Templating - Home Assistant. If anyone is interested I can share all of my math library that supports polygon zones (and more)…
Here is an example of how I have defined a sensor template to have the “device is in a polygon zone”: This sensors state is either true or false…
{% from ‘polygon_funcs.jinja’ import device_in_zone %}
{% set pt1 = [ state_attr(‘device_tracker.an_iphone_3’, ‘longitude’), state_attr(‘device_tracker.an_iphone_3’, ‘latitude’) ] %}
{% set result = device_in_zone(pt1, ‘sensor.any_defined_polygon_zone’) %}
{{ result }}
And multiple sensors such as this can be combined with “and’s” or “or’s” to determine if a device is in the “intersection” or “union” of multiple zones…
The polygon definitions are stored in configuration.yaml…as:
  • sensor:
    - name: “any defined polygon zone”
    unique_id: “any_defined_polygon_zone”
    state: “Polygon”
    attributes:
    p_1: “[-115.8550, 37.4200]”
    p_2: “[-115.6500, 37.4200]”
    p_3: “[-115.6500, 37.2000]”
    p_4: “[-115.8550, 37.2000]”
    p_5: “[-115.8550, 37.4200]”
    is_closed: true
My solution is a very simple generic one without the need of an integration or add-on - just a proven math library that automatically loads on a start or restart…I’ve tested a 54 vertices polygon and the math executes very quickly…
I’m very interested in what you’ve implemented.
Ok. I finally got my project documented well enough so that I think others can use it. Here is my github repo for this ‘add-on’. It is a work in progress, so there may be a few quirks to iron out as it gets used by others. GitHub - Area4949/ha-cogo_plus
Current supported “zone shapes” are circles, polygons, and polylines (cooridors).
