ok,
i understand what is tthe problem .
the first version of the code was counting only the filtration duration time during one day.
so when the filtration start on day D and stop on D+1 , the stop automation wasn’t working.
so i added a second trigger for stopping the filtration based on duration since last trigger ( of the pump start)
you will find it at line 203 in pool.yaml
As promised, this is the result. I changed the starting time to 00:01. And as you can see, the “Auto filtration time” is not correct (08:04:48) and this corresponds to
It seems that your interface yaml works only when the filtration is working : now + scheduled_working_time - real_working_time = (now + remaining_working_time) when filtration is on. But when filtration if off, it is equal to : now + scheduled_working_time - previous_working_time ( whichi is equivalent to now if scheduled_working_time is equal to previous_working_time (as it did not start yet).
which makes sense
you need to know the stop time only if something is running
maybe i could had a condition in order to display “—” if the filtration is not running
You are true ! But, in my case, as the filtration is running at night in winter, the 'end of filtration" was always unconsistent.
Thank you for the discussion anyway and thank you for your really good solution. The other one is locked with two periods and cannot be adjusted as yours.
For your information, I use esphome with an esp32 to control through relays the pump, the speed of the pump, and to sense the level, the pump flow, the temperatures.
Bonnes fêtes de fin d’année !
With this automation, if I want the automatic filtration to resume after a 30 minute break after 4 hours of filtration, I have to add something more I think
Bonjour Laurent,
J’ai déjà installé l’automatisation de oncleben31 qui fonctionne mais je voulais tester ton plan pour voir la différence.
Sur celle de oncleben31 on ne peut pas choisir une heure de départ et un temps donné de filtration en mode manuel.
Par contre je n’arrive pas à ajouter la partie sensor de ton pool.yaml.
Peut-être pourrait tu m’aider ?
dans le fichier pool.yaml il faut remplacer tous les sensor.pool_water_kalman par le nom de ton sensor de température
par exemple avec le file editor comme dans la capture ci dessous
C’est bon j’ai réussi, je ne sais pas ce qui s’est passé la première fois j’ai du faire une erreur d’écriture.
Par contre je n’ai pas duration since last autofiltration, statut indisponible.
En tout cas,
Merci pour ton travail.
Bonjour !
Je suis intéressé pour remplacer également mon programmateur mécanique, où je dois en théorie changé à un nombre d’heures par jour équivalent à la température de la piscine divisé par 2 d’après mon pisciniste.
Est-ce que tu/vous pouvez me confirmer que vous êtes satisfait de votre solution au quotidien et me donner une idée approximative du budget svp?
Merci !
oui tout fonctionne très bien chez moi
diviser le temps par 2 pour avoir le temps de filtraiton est une approche simplifiée quand on doit le faire manuellement.
je l’ai également comparé aux infos récupéré sur le blog d’oklyn
au niveau budget, il faut :
un switch pour controler la pompe ( j’ai un utiliser celui la ~15€
une sonde de temperature . j’ai utilisé un esp32 avec des sondes dallas pour etre en filaire , mais il existe des sondes sans fil comme la Casa.IA CTHS-317-ET
it’s probably because the automation is stored in pool.yaml instead of automation.yaml
both work,
if you migrate you will be able to edit it in GUI
i’m not sure which is best for you
on my side i edit the automation in the pool.yaml, so i don’t migrate
je suis en train de remplacer mon Domoticz par HA, ma gestion du temps de filtration est actuellement faite par Domoticz, je commence donc à m’inétrésser de prêt à votre solution pour le remplacer.
tout semble ok mais j’ai une erreur "entité non disponible : sensor.pompe_piscine_on_today
possible que ce soit par ce que ça n’a pas encore tourner.
par contre autre soucis dans le lovelace, le chemin vers le PNG de standard est KO :
image: /local/IMG/oklyn.png
j’ai du remplacer par standard, ou alors j’ai râter un truc
autre question, est-il possible de rajouter un mode Off et Manuel , en mode Off cela coupe la filtration immédiatement, et mode manuel ça active la pompe sans se soucier du temps de filtration ?
j’explique pourquoi :
ma piscine possède un filtre papier que je doit donc nettoyer très régulièrement. pour ça il faut que je coupe la pompe (mode off), et parfois j’ai besoin d’avoir une filtration en continue (suite à un traitement par exemple)
ce n’est peut être pas très claire donc n’hésitez pas à me demander un complément si besoin ou me dire votre façon de voir les choses.
Dans tous les cas merci beaucoup pour votre travail !
