Pool auto filtration based on temperature
Hello @froggy.laurent,
I’ve been looking for something like this for some time now :slight_smile:
It looks excellent.
Just a quick contribution as I’m installing it manually.
I’ve noticed a typo :
sensor.pool_water_temp_kalman
should read
sensor.pool_water_kalman
I’ll let you know if I find some other correction needed as there was some updates on HA since your last post.
Thanks again :slight_smile:
happy to help
i can’t find sensor.pool_water_temp_kalman in the github repo.
are you sure you got the last version ?
Maybe I’m not using the right link but this is what’s in GitHub :
while the instructions states
ok, understood,
the github is correct, and the install instructions on first post was wrong.
it’s corrected, thanks for pointing me this :slight_smile:
Hi, i don’t understand why you have :
      - platform: numeric_state
        entity_id: sensor.last_autostart_triggered_since
        above: sensor.auto_cycle_duration_abacus
in
alias: '[Pool] auto filtration cycle stop (abacus)'
because with this, the filtration stop even if filtration are not reched the “auto cycle duration”, example, if you stop the filtration (clean filter needed), the filtration is stopped too early for me.
Hi aldebert.
It’s a quick fix of a bug reported by an user in a specific case when the abacus theoretical stop is after the end of the day ( for example in summer is the start time is in the afternoon).
So I added this second trigger based on last_triggered to trigger the stop for this specific case.
There is probably a more sophisticated way to do this .
Ok, i undenstand.
i’ve removed this condition for now. i will try to find another way to this if i can find a smarter way.
Hello and thanks for your job.
I tried oncleben’s pool but didnt succeed to make it working.
May i ask an request?
It is possible to add 2 range of time per day for ’heures creuses’ to make the pump working in thoses times?
I got an jeedom plugin which run like this too, and you gain a lot in power consumption.
hi,
yes i see what you mean, but i can’t think about a quick and easy way to implement this.
I will think about it, maybe a brilliant idea will pop up :sweat_smile:
If you dont mind, i can try to implement something.
And adding somes stuffs too, like choosing active or passive winter mode
great !
yes don’t hesitate to propose a improvement on github
hello
I wan’t to try your filtration script
Are the files in your github updated with all the modifications find in tne conversation?
Thank’s
Hi.
The part discussed with potiron is not implemented.
Everything above yes
Hello
I installed and seem’s to work.
i use the the pool filtration mode and i have this msg. MAy i wait the day is ended or i have a problem?
Thank’s
Et tant que j’y suis une deuxième question
Si je change les textes aangalis en francias ca va pas tout planter… lol
Juste un reboot et ca devrait le faire?
you need to switch on the pool filtration for some minute in order to populate sensor.pompe_piscine_on_today
tout ce qui est dans la card lovelace aucun probleme, par contre le nom de sensor il faut bien le remplacer partout pour garder le lien, sinon ca ne marchera plus
exemple :
Idem After 2 hours in this mode.
i don t understand the problem
Ca va etre compliqué, operation d’urgence du canal carpien :grin:
bon courage…
