Pool monitor and control help
Got a swimming pool in my new place that I’d like to monitor and possibly control through HA. Shots here.
Best lead I’ve got for monitoring is this diy solar powered temperature monitor. Considering adding in a chlorine probe as well when assembling but that’s all part of the test & build phase. An alternative is getting this tuya monitor and swapping in an ESP8266. That said, I have no idea how to integrate it into the pool setup.
Control seems to be isolated to the 2 din switches for the pump. I can swap those out for similar Zigbee models.
That’s as far as I’ve managed to figure out for the entire setup.
Here is a pool integration that will control all the equipment on your pool. Check out the wiki for chemistry control as well as equipment control for common pumps, heaters, and valves. There is also a complete HA INTEGRATION.
