Thanks, this code works quite well!
I made a few changes:
- added the chlorine as reported by the meter like in another post, but note the value is in mg/L and not ppm, and it requires 1 decimal, otherwise it will often just report 0
- my device reports °C, and that’s what I need
- pH seems to be reported with 1 decimal only, so I set that
- I removed the “start scanning” and “stop scanning” buttons - they don’t do anything since continuous scanning is the default anyway for the ble_tracker. If you don’t want that, you have to set “continuous: false”, but if you use the esp32 as bluetooth proxy as well, this won’t work anymore. Setting “active: false” is just to avoid asking passive devices for additional data after receiving a packet, it’s irrelevant for the YC01, which requires an active connection. So the comment in the code “stop active scanning” is actually incorrect to my knowledge.
- in the code in the referenced post, the active time was 25min instead of 2min. I correct that, but at home, I have removed the timer entirely. Let’s see how long battery will last…
- EDIT: I also changed the platform type from the default arduino to esp-idf, as that is recommended for bluetooth proxies, so I guess it is better here as well (this is not shown in my code). This change has to be done via usb connection, not OTA.
Hope that helps…
esp32_ble_tracker:
scan_parameters:
active: false
binary_sensor:
- platform: status
icon: mdi:bluetooth-connect
name: "BLE Connected"
time:
- platform: homeassistant
on_time:
# Turn on BLE client every 30 minutes for 2 minutes
- seconds: 0
minutes: /30
then:
- switch.turn_on: ble_switch
- delay: 2min
- switch.turn_off: ble_switch
## To initiate to connection with the BLE device ##
ble_client:
- mac_address: C0:00:00:0x:xx:xx #Use the MAC address of your BLE device
on_connect: #### Actions to perform when connecting to the BLE device ####
then:
#### Wait until characteristic is discovered ####
- wait_until:
lambda: |-
esphome::ble_client::BLEClient* client = id(ble_yc01);
auto service_uuid = 0xFF01;
auto char_uuid = 0xFF02;
//#### When waiting for connection, we extract the available characteristics ####
esphome::ble_client::BLECharacteristic* chr = client->get_characteristic(service_uuid, char_uuid);
return chr != nullptr;
#### Official connection to the BLE device with the desired characteristic ####
- lambda: |-
ESP_LOGD("ble_client_lambda", "Connected to BLE-YC01");
id(ble_yc01_ble_connected).publish_state(true);
if (chr == nullptr) {
ESP_LOGW("ble_client", "[0xFF01] Characteristic not found. State update can not be written.");
on_disconnect:
then:
- lambda: |-
ESP_LOGD("ble_client", "Disconnected from BLE-YC01");
id(ble_yc01_ble_connected).publish_state(false);
## Sensors associated with the BLE device ##
sensor: #### Template sensor as their values are publish from a lambda or the BLE client ####
unit_of_measurement: "µS/cm"
accuracy_decimals: 0
state_class: measurement
icon: mdi:water-opacity
unit_of_measurement: "ppm"
name: "BLE-YC01 Temperature"
unit_of_measurement: "C"
accuracy_decimals: 1
device_class: temperature
unit_of_measurement: "mV"
device_class: voltage
unit_of_measurement: "pH"
icon: mdi:ph
unit_of_measurement: "%"
device_class: battery
icon: mdi:battery
unit_of_measurement: "mg/L"
- platform: ble_client #### Sensor required to manage values coming from the BLE device ####
ble_client_id: ble_yc01
type: characteristic
update_interval: 30s
internal: true
service_uuid: FF01
characteristic_uuid: FF02
notify: true
#### Lambda to decode values and push to the associated sensors ####
lambda: |-
if (x.size() == 0) return NAN;
//ESP_LOGD("ble_client.receive", "value received with %d bytes: [%.*s]", x.size(), x.size(), &x[0]); // #### Useful for debugging ####
// ### DECODING ###
uint8_t tmp = 0;
uint8_t hibit = 0;
uint8_t lobit = 0;
uint8_t hibit1 = 0;
uint8_t lobit1 = 0;
auto message = x;
for (int i = x.size() -1 ; i > 0; i--) {
tmp=message[i];
hibit1=(tmp&0x55)<<1;
lobit1=(tmp&0xAA)>>1;
tmp=message[i-1];
hibit=(tmp&0x55)<<1;
lobit=(tmp&0xAA)>>1;
message[i]=~(hibit1|lobit);
message[i-1]=~(hibit|lobit1);
//ESP_LOGD("ble_client.receive", "value received with %d bytes: [%.*s]", message.size(), message.size(), &message[0]); // #### For debug ####
// #### Extraction of individual values ####
auto temp = ((message[13]<<8) + message[14]);
auto ph = ((message[3]<<8) + message[4]);
auto orp = ((message[20]<<8) + message[21]);
auto battery = ((message[15]<<8) + message[16]);
auto ec = ((message[5]<<8) + message[6]);
auto tds = ((message[7]<<8) + message[8]);
auto cloro = ((message[11]<<8) + message[12]);
// #### Sensors updated with new values
id(ble_yc01_temperature_sensor).publish_state(temp/10.0);
id(ble_yc01_ph_sensor).publish_state(ph/100.0);
id(ble_yc01_orp_sensor).publish_state(orp);
id(ble_yc01_battery).publish_state(battery/31.9);
id(ble_yc01_ec_sensor).publish_state(ec);
id(ble_yc01_tds_sensor).publish_state(tds);
id(ble_yc01_cloro).publish_state(cloro/10.0);
return 0.0; // this sensor isn't actually used other than to hook into raw value and publish to template sensors
switch: #### To switch on and off the communication with the BLE device ####
name: "Enable BLE-YC01"
