If I use the yinmik app, the esp doesn’t connect anymore, turning on/off doesn’t help anymore,
Someone said, putting out battery, but what helps for me is to turn off/on BT mode on the ble device itself, afterwards, the esp connects again
did it other way around, resetting ESP
Ah ok , why does it work when resetting/rebooting esp? What’s the difference with the switch turning off/on again?
I also got the false cl values but my ph is fine.
Strange:
for me its fine, once the PH was settled
i got a couple of correct readings, but after half a day i got this value.
do yo see this:
or do you see there the value 6554 ?
are you also sure its still updating every 30 min? maybe its still an old value
i see it as shown on your image.
i’ve used it for a month and i got correct values on the screen.
Now i’ve integrated it into esphome and i can’t get correct values of cl.
and whats the PH value itself on the device? (not in HA)
it was last updated yesterday. ph 6 hours ago and temp 4 mins. ago.
the value is 7.3
strange, for me its working now, maybe the value in HA is wrong? are you sure its also 7.3 on the device itself?
i can’t see it right now, i’m not at home.
But it has been always 7.2 till 7.5 range
I’ll check later
i took the batteries out, and after that i got a correct cl reading.
But 1 hour later again — on the display and 6.553,5 in home assistant.
the last mg/l value was 1.2 mg/l and ph is 7.3
for me when the switch turns on every 30 min, the sensors is not always connected, not sure why, its not a distance issue
anyone else seeing this too ? is the 2 min maybe too short?
I’ve seen this also time to time, but if connection failed, in 100% of case, next half-hour it success
ok, lets see what happens
what code are you using? the last version from this post?
maybe this one is too short? maybe it needs like 15 sec instead?
update_interval: 30s
from this part:
- platform: ble_client #### Sensor required to manage values coming from the BLE device ####
ble_client_id: ble_yc01
type: characteristic
internal: true
service_uuid: FF01
characteristic_uuid: FF02
notify: true
out of scope, but can you share the yaml of this card ?
