matatools
(matatookls)
1
I’m trying to dynamically manage the pool pump time based on the water temperature.
The point is that I would switch on the pump at a specific time that is calculated by this template, but it doesn’t start. What am I missing?
sensors:
orario_inizio_calcolato:
unique_id: orario_inizio_calcolato
value_template: >
{% set ore_funzionamento_stimate = states('sensor.ore_funzionamento_stimate') | float %}
{% set ore_da_sottrarre = ore_funzionamento_stimate / 2 %}
{% set ora_iniziale = strptime('13:00', '%H:%M') %}
{% set ora_finale = ora_iniziale - timedelta(hours=ore_da_sottrarre) %}
{{ ora_finale.strftime('%H:%M:%S') }}
Output is this but seems is not recognize as time trigger automation.
tom_l
2
You’re missing the device class.
https://www.home-assistant.io/docs/automation/trigger/#sensors-of-datetime-device-class
sensors:
device_class: timestamp ## <-------------THIS
value_template: >
You really should be using the new template integration for new template sensors.
configuration.yaml (not sensors.yaml)
template:
- sensor:
- name: Orario Inizio Calcolato
state: >
matatools
(matatookls)
3
Thank you, I tried to add device class, use the new template syntax and write everything in a packages yaml.
Anyway even I tried to simplify the template, I’m getting crazy to make it work:
Sensor is shown as UNKNOWN but running the template in developer tools’s template editor it seems working:
template:
- sensor:
- name: Ore stimate funzionamento
unique_id: estimated_running_time
state: >
{{ (((states('sensor.gw2000a_pool_temperature') | float ) * (1 + (states('input_number.delta_ore_funzionamento') | float / 100))) | round(0, 'ceil') * 3600) | timestamp_custom('%H:%M', false) }}
What am I doing wrong?
tom_l
4
Did you restart HA as you are using the template integration for the first time?
matatools
(matatookls)
5
Yes, I restarted several times
tom_l
6
Are there any errors in your log related to this sensor?
matatools
(matatookls)
7
Emhmm… yes. I didn’t notice:
tom_l
8
matatools
(matatookls)
9
Ok thank you, it show the values now but in date-time format.
The point is now that removing date from the template it gives “unknown”.
It should:
- calculate the pump WORKING TIME based on the half of pool water temperature
- calculate the START time deducting half of working time from 14:00
- calculate the STOP time adding half of working time from 14:00
The result is this:
using this code:
template:
- sensor:
state: >
{{ (((states('sensor.gw2000a_pool_temperature') | float / 2) * (1 + (states('input_number.delta_ore_funzionamento') | float / 100))) | round(0, 'ceil') * 3600) | timestamp_custom('%Y-%m-%dT%H:%M:%S%z', false) }}
- sensor:
- name: Pump start time (automatic)
unique_id: Pump_start_time_automatic
state: >
{{ (as_timestamp(strptime('14:00', '%H:%M')) - ((((states('sensor.gw2000a_pool_temperature') | float / 2 / 2) * (1 + (states('input_number.delta_ore_funzionamento') | float / 100))) | round(0, 'ceil') * 3600))) | timestamp_custom('%Y-%m-%dT%H:%M:%S%z', true) }}
- sensor:
- name: Pump stop time (automatic)
unique_id: Pump_stop_time_automatic
state: >
{{ (as_timestamp(strptime('14:00', '%H:%M')) + ((((states('sensor.gw2000a_pool_temperature') | float / 2 / 2) * (1 + (states('input_number.delta_ore_funzionamento') | float / 100))) | round(0, 'ceil') * 3600))) | timestamp_custom('%Y-%m-%dT%H:%M:%S%z', true) }}
