Pool Pump Timer
Hi guys! Im trying to adapt this, to run my pump for maybe 2 hours in the morning and hours of an evening every day.
Right now im not sure how its getting its timing, I think it just looks for sensor state changes. Is it possible to adapt it to run on a timer?
How can I add this in HA?
# Check if pool pump is supposed to run, and turn it on or off accordingly
import logging
from datetime import timedelta
from homeassistant.helpers.sun import get_astral_event_date
from homeassistant.util import dt as dt_util
_LOGGER = logging.getLogger(__name__)
DOMAIN = 'pool_pump_service'
ATTRIBUTE_SWITCH_ENTITY_ID = 'switch_entity_id'
OFF_SEASON_MAX_DURATION = 6.0
OFF_SEASON_RUN_1_AFTER_SUNRISE_OFFSET_MINS = 120
OFF_SEASON_1ST_BREAK_MINUTES = 60
SWIMMING_SEASON_MAX_DURATION = 8.25
SWIMMING_SEASON_RUN_1_AFTER_SUNRISE_OFFSET_MINS = 75
SWIMMING_SEASON_BREAK_1_MINUTES = 60
SWIMMING_SEASON_BREAK_2_MINUTES = 165
def setup(hass, config):
    """Set up is called when Home Assistant is loading our component."""
    def switch_pool_pump(switch_entity_id, target_state):
        switch = hass.states.get(switch_entity_id)
        if switch:
            if switch.state == target_state:
                # Already in the correct state
                _LOGGER.info("Switch is in correct state: %s", target_state)
            else:
                # Not in the correct state
                data = { "entity_id": switch_entity_id }
                if target_state == 'on':
                    hass.services.call('homeassistant', 'turn_on', data)
                else:
                    hass.services.call('homeassistant', 'turn_off', data)
                _LOGGER.info("Switched from '%s' to '%s'", switch.state,
                             target_state)
        else:
            _LOGGER.warning("Switch unavailable: %s", switch_entity_id)
    def handle_check(call):
        _LOGGER.info("Starting pool pump check")
        switch_entity_id = call.data.get(ATTRIBUTE_SWITCH_ENTITY_ID)
        # Read the pool pump configuration
        mode = hass.states.get('input_select.pool_pump')
        swimming_season = hass.states.get('input_boolean.swimming_season')
        run_hours_swimming_season = min(SWIMMING_SEASON_MAX_DURATION,
                                        float(hass.states.get(
                                              'input_number.run_pool_pump_hours_swimming_season').state))
        run_hours_off_season = min(OFF_SEASON_MAX_DURATION,
                                         'input_number.run_pool_pump_hours_off_season').state))
        _LOGGER.info("* Pool pump mode: %s", mode.state)
        _LOGGER.info("* Swimming season: %s", swimming_season.state)
        _LOGGER.info("* Pool pump run hours swimming season: %s",
                     run_hours_swimming_season)
        _LOGGER.info("* Pool pump run hours off season: %s",
                     run_hours_off_season)
        # Only check if pool pump is set to 'Auto'
        if mode.state == 'Auto':
            _LOGGER.info("Pool pump set to 'Auto'")
            # Get sun details for today
            now = dt_util.now()
            _LOGGER.info("* Time is now %s", now)
            sun = hass.states.get('sun.sun')
            if sun.state == 'above_horizon':
                _LOGGER.info("* Sun above horizon")
                date = now.date()
                sunrise = get_astral_event_date(hass, 'sunrise', date)
                sunset = get_astral_event_date(hass, 'sunset', date)
                _LOGGER.info("* Sunrise: %s",
                             sunrise.astimezone(hass.config.time_zone))
                _LOGGER.info("* Sunset: %s",
                             sunset.astimezone(hass.config.time_zone))
                if swimming_season.state == 'on':
                    # Swimming Season (Summer)
                    _LOGGER.info("* Swimming season")
                    duration1 = run_hours_swimming_season * 60.0 * 0.25
                    duration2 = run_hours_swimming_season * 60.0 * 0.5
                    duration3 = run_hours_swimming_season * 60.0 * 0.25
                    _LOGGER.info(
                        "* Run pool pump 3 times for %s/%s/%s minutes",
                        duration1, duration2, duration3)
                   # Check for 1st run
                    run_1_start = sunrise + timedelta(
                        minutes=SWIMMING_SEASON_RUN_1_AFTER_SUNRISE_OFFSET_MINS)
                    run_1_stop = run_1_start + timedelta(minutes=duration1)
                    _LOGGER.info("* Run 1/3: %s - %s",
                                 run_1_start.astimezone(hass.config.time_zone),
                                 run_1_stop.astimezone(hass.config.time_zone))
                    if run_1_start <= now <= run_1_stop:
                        # Turn on pool pump
                        _LOGGER.info("* Pool pump should be on (Run 1/3)")
                        switch_pool_pump(switch_entity_id, 'on')
                    else:
                        # Check for 2nd run
                        run_2_start = run_1_stop + timedelta(
                            minutes=SWIMMING_SEASON_BREAK_1_MINUTES)
                        run_2_stop = run_2_start + timedelta(minutes=duration2)
                        _LOGGER.info("* Run 2/3: %s - %s",
                                     run_2_start.astimezone(
                                     run_2_stop.astimezone(
                        if run_2_start <= now <= run_2_stop:
                            # Turn on pool pump
                            _LOGGER.info("* Pool pump should be on (Run 2/3)")
                        else:
                            # Check for 3rd run
                            run_3_start = run_2_stop + timedelta(
                                minutes=SWIMMING_SEASON_BREAK_2_MINUTES)
                            run_3_stop = run_3_start + timedelta(
                                minutes=duration3)
                            _LOGGER.info("* Run 3/3: %s - %s",
                                         run_3_start.astimezone(
                                         run_3_stop.astimezone(
                            if run_3_start <= now <= run_3_stop:
                                # Turn on pool pump
                                _LOGGER.info(
                                    "* Pool pump should be on (Run 3/3)")
                            else:
                                # Turn off pool pump
                                _LOGGER.info("* Pool pump should be off")
                                switch_pool_pump(switch_entity_id, 'off')
                else:
                    # Off Season (Winter)
                    _LOGGER.info("* Off season")
                    duration = run_hours_off_season * 60.0 * 0.5
                    _LOGGER.info("* Run pool pump 2 times for %s/%s minutes",
                                 duration, duration)
                    # Check for 1st run
                        minutes=OFF_SEASON_RUN_1_AFTER_SUNRISE_OFFSET_MINS)
                    run_1_stop = run_1_start + timedelta(minutes=duration)
                    _LOGGER.info("* Run 1/2: %s - %s",
                        # Turn on pool pump
                        _LOGGER.info("* Pool pump should be on (Run 1/2)")
                    else:
                        # Check for 2nd run
                            minutes=OFF_SEASON_1ST_BREAK_MINUTES)
                        run_2_stop = run_2_start + timedelta(minutes=duration)
                        _LOGGER.info("* Run 2/2: %s - %s",
                            # Turn on pool pump
                            _LOGGER.info("* Pool pump should be on (Run 2/2)")
                        else:
            else:
                _LOGGER.info("* Sun below horizon")
                # Turn pool pump if it's still running
        else:
            _LOGGER.info("Pool pump set to '%s'", mode.state)
    hass.services.register(DOMAIN, 'check', handle_check)
    # Return boolean to indicate that initialisation was successfully.
    return True
You can add the original via HACS, or if you are customising the component then you can still follow the manual installation steps as documented.
