Popp lock relay - unable to unlock door lock
Hi!
I have an Rpi 2B+ with Hass 101.3 onboard + Zway integration.
Relay added as secure device as it mentioned here at docs page.
All the etities of lock are visible at states page, but the lock entity’ states cannot be operated.
The relay is OK, i have Ubuntu Hass instance nearby, with original zway server. Everything pretty fine if i control the same Popp relay but via Zway - to - MQTT topic, listenined it at Hass.
Also, i’ve checked the logs of z-wave integation, ad it seems that Openzwave sends the wrong command to the lock relay
2019-11-18 20:18:24.670 Info, Node041, Value::Set - COMMAND_CLASS_DOOR_LOCK - Locked - 0 - 1 - True
2019-11-18 20:18:24.671 Info, Node041, Value_Lock::Set - Requesting lock to be Locked
2019-11-18 20:18:24.671 Detail, Node041, Queuing (Send) DoorLockCmd_Set (Node=41): 0x01, 0x0a, 0x00, 0x13, 0x29, 0x03, 0x62, 0x01, 0xff, 0x25, 0x37, 0x42
2019-11-18 20:18:24.671 Detail, Node041, Queuing (Send) DoorLockCmd_Get (Node=41): 0x01, 0x09, 0x00, 0x13, 0x29, 0x02, 0x62, 0x02, 0x25, 0x38, 0xb3
2019-11-18 20:18:24.672 Detail,
2019-11-18 20:18:24.672 Info, Node041, Sending (Send) message (Callback ID=0x37, Expected Reply=0x04) - DoorLockCmd_Set (Node=41): 0x01, 0x0a, 0x00, 0x13, 0x29, 0x03, 0x62, 0x01, 0xff, 0x25, 0x37, 0x42
2019-11-18 20:18:24.681 Detail, Node041,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-11-18 20:18:24.681 Detail, Node041,   ZW_SEND_DATA delivered to Z-Wave stack
2019-11-18 20:18:25.935 Detail, Node041,   Received: 0x01, 0x18, 0x00, 0x13, 0x37, 0x00, 0x00, 0x7d, 0x00, 0xca, 0x7f, 0x7f, 0x7f, 0x7f, 0x00, 0x01, 0x03, 0x00, 0x00, 0x00, 0x00, 0x42, 0x04, 0x00, 0x00, 0x30
2019-11-18 20:18:25.935 Detail, Node041,   ZW_SEND_DATA Request with callback ID 0x37 received (expected 0x37)
2019-11-18 20:18:25.936 Info, Node041, Request RTT 1263 Average Request RTT 1271
2019-11-18 20:18:25.936 Detail,   Expected callbackId was received
2019-11-18 20:18:34.673 Error, Node041, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-11-18 20:18:34.673 Detail, Node041, Removing current message
2019-11-18 20:18:34.674 Detail, Node041, Notification: Notification - TimeOut
2019-11-18 20:18:34.704 Detail,
2019-11-18 20:18:34.704 Info, Node041, Sending (Send) message (Callback ID=0x38, Expected Reply=0x04) - DoorLockCmd_Get (Node=41): 0x01, 0x09, 0x00, 0x13, 0x29, 0x02, 0x62, 0x02, 0x25, 0x38, 0xb3
2019-11-18 20:18:34.713 Detail, Node041,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-11-18 20:18:34.714 Detail, Node041,   ZW_SEND_DATA delivered to Z-Wave stack
2019-11-18 20:18:37.006 Detail, Node041,   Received: 0x01, 0x18, 0x00, 0x13, 0x38, 0x00, 0x00, 0xe5, 0x00, 0xca, 0x7f, 0x7f, 0x7f, 0x7f, 0x00, 0x01, 0x03, 0x00, 0x00, 0x00, 0x00, 0x42, 0x04, 0x00, 0x00, 0xa7
2019-11-18 20:18:37.006 Detail, Node041,   ZW_SEND_DATA Request with callback ID 0x38 received (expected 0x38)
2019-11-18 20:18:37.007 Info, Node041, Request RTT 2302 Average Request RTT 1786
2019-11-18 20:18:37.007 Detail,   Expected callbackId was received
2019-11-18 20:18:44.704 Error, Node041, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-11-18 20:18:44.704 Detail, Node041, Removing current message
2019-11-18 20:18:44.705 Detail, Node041, Notification: Notification - TimeOut
2019-11-18 20:22:32.036 Info, Node041, Value_Lock::Set - Requesting lock to be Unlocked
2019-11-18 20:22:32.036 Detail, Node041, Queuing (Send) DoorLockCmd_Set (Node=41): 0x01, 0x0a, 0x00, 0x13, 0x29, 0x03, 0x62, 0x01, 0x00, 0x25, 0x4b, 0xc1
2019-11-18 20:22:32.037 Detail, Node041, Queuing (Send) DoorLockCmd_Get (Node=41): 0x01, 0x09, 0x00, 0x13, 0x29, 0x02, 0x62, 0x02, 0x25, 0x4c, 0xc7
2019-11-18 20:22:33.491 Detail, Node029,   Received: 0x01, 0x0d, 0x00, 0x04, 0x00, 0x1d, 0x05, 0x31, 0x05, 0x05, 0x01, 0x16, 0xcd, 0x00, 0x05
2019-11-18 20:22:33.491 Info, Node029, Response RTT 1718 Average Response RTT 1914
2019-11-18 20:22:33.491 Info, Node029, Received SensorMultiLevel report from node 29, instance 1, Relative Humidity: value=22%
2019-11-18 20:22:33.491 Detail, Node029, Refreshed Value: old value=22, new value=22, type=decimal
2019-11-18 20:22:33.492 Detail, Node029, Changes to this value are not verified
2019-11-18 20:22:33.492 Detail, Node029,   Expected reply and command class was received
2019-11-18 20:22:33.492 Detail, Node029,   Message transaction complete
2019-11-18 20:22:33.492 Detail, Node029, Removing current message
2019-11-18 20:22:33.492 Detail, Node029, Notification: ValueChanged
2019-11-18 20:22:33.553 Detail,
2019-11-18 20:22:33.554 Info, Node041, Sending (Send) message (Callback ID=0x4b, Expected Reply=0x04) - DoorLockCmd_Set (Node=41): 0x01, 0x0a, 0x00, 0x13, 0x29, 0x03, 0x62, 0x01, 0x00, 0x25, 0x4b, 0xc1
2019-11-18 20:22:33.564 Detail, Node041,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-11-18 20:22:33.564 Detail, Node041,   ZW_SEND_DATA delivered to Z-Wave stack
2019-11-18 20:22:34.841 Detail, Node041,   Received: 0x01, 0x18, 0x00, 0x13, 0x4b, 0x00, 0x00, 0x80, 0x00, 0xc3, 0x7f, 0x7f, 0x7f, 0x7f, 0x00, 0x01, 0x03, 0x00, 0x00, 0x00, 0x00, 0x42, 0x04, 0x00, 0x00, 0xb8
2019-11-18 20:22:34.841 Detail, Node041,   ZW_SEND_DATA Request with callback ID 0x4b received (expected 0x4b)
2019-11-18 20:22:34.841 Info, Node041, Request RTT 1287 Average Request RTT 1536
2019-11-18 20:22:34.842 Detail,   Expected callbackId was received
2019-11-18 20:22:38.029 Info, Node041, Value::Set - COMMAND_CLASS_DOOR_LOCK - Locked - 0 - 1 - False
2019-11-18 20:22:38.030 Info, Node041, Value_Lock::Set - Requesting lock to be Unlocked
2019-11-18 20:22:38.030 Detail, Node041, Queuing (Send) DoorLockCmd_Set (Node=41): 0x01, 0x0a, 0x00, 0x13, 0x29, 0x03, 0x62, 0x01, 0x00, 0x25, 0x4d, 0xc7
2019-11-18 20:22:38.030 Detail, Node041, Queuing (Send) DoorLockCmd_Get (Node=41): 0x01, 0x09, 0x00, 0x13, 0x29, 0x02, 0x62, 0x02, 0x25, 0x4e, 0xc5
2019-11-18 20:22:43.555 Error, Node041, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-11-18 20:22:43.555 Detail, Node041, Removing current message
2019-11-18 20:22:43.555 Detail, Node041, Notification: Notification - TimeOut
2019-11-18 20:22:43.614 Detail,
2019-11-18 20:22:43.615 Info, Node041, Sending (Send) message (Callback ID=0x4c, Expected Reply=0x04) - DoorLockCmd_Get (Node=41): 0x01, 0x09, 0x00, 0x13, 0x29, 0x02, 0x62, 0x02, 0x25, 0x4c, 0xc7
2019-11-18 20:22:43.624 Detail, Node041,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-11-18 20:22:43.624 Detail, Node041,   ZW_SEND_DATA delivered to Z-Wave stack
2019-11-18 20:22:46.060 Detail, Node041,   Received: 0x01, 0x18, 0x00, 0x13, 0x4c, 0x00, 0x00, 0xf3, 0x00, 0xc3, 0x7f, 0x7f, 0x7f, 0x7f, 0x00, 0x01, 0x03, 0x00, 0x00, 0x00, 0x00, 0x42, 0x05, 0x00, 0x00, 0xcd
2019-11-18 20:22:46.060 Detail, Node041,   ZW_SEND_DATA Request with callback ID 0x4c received (expected 0x4c)
2019-11-18 20:22:46.060 Info, Node041, Request RTT 2446 Average Request RTT 1991
2019-11-18 20:22:46.061 Detail,   Expected callbackId was received
2019-11-18 20:22:53.615 Error, Node041, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-11-18 20:22:53.615 Detail, Node041, Removing current message
2019-11-18 20:22:53.615 Detail, Node041, Notification: Notification - TimeOut
2019-11-18 20:22:53.644 Detail,
2019-11-18 20:22:53.645 Info, Node041, Sending (Send) message (Callback ID=0x4d, Expected Reply=0x04) - DoorLockCmd_Set (Node=41): 0x01, 0x0a, 0x00, 0x13, 0x29, 0x03, 0x62, 0x01, 0x00, 0x25, 0x4d, 0xc7
2019-11-18 20:22:53.653 Detail, Node041,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-11-18 20:22:53.654 Detail, Node041,   ZW_SEND_DATA delivered to Z-Wave stack
2019-11-18 20:22:54.908 Detail, Node041,   Received: 0x01, 0x18, 0x00, 0x13, 0x4d, 0x00, 0x00, 0x7d, 0x00, 0xca, 0x7f, 0x7f, 0x7f, 0x7f, 0x00, 0x01, 0x03, 0x00, 0x00, 0x00, 0x00, 0x42, 0x04, 0x00, 0x00, 0x4a
2019-11-18 20:22:54.908 Detail, Node041,   ZW_SEND_DATA Request with callback ID 0x4d received (expected 0x4d)
2019-11-18 20:22:54.908 Info, Node041, Request RTT 1263 Average Request RTT 1627
2019-11-18 20:22:54.909 Detail,   Expected callbackId was received
2019-11-18 20:23:03.646 Error, Node041, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-11-18 20:23:03.646 Detail, Node041, Removing current message
2019-11-18 20:23:03.647 Detail, Node041, Notification: Notification - TimeOut
2019-11-18 20:23:03.694 Detail,
2019-11-18 20:23:03.694 Info, Node041, Sending (Send) message (Callback ID=0x4e, Expected Reply=0x04) - DoorLockCmd_Get (Node=41): 0x01, 0x09, 0x00, 0x13, 0x29, 0x02, 0x62, 0x02, 0x25, 0x4e, 0xc5
2019-11-18 20:23:03.702 Detail, Node041,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-11-18 20:23:03.702 Detail, Node041,   ZW_SEND_DATA delivered to Z-Wave stack
2019-11-18 20:23:04.942 Detail, Node041,   Received: 0x01, 0x18, 0x00, 0x13, 0x4e, 0x00, 0x00, 0x7c, 0x00, 0xca, 0x7f, 0x7f, 0x7f, 0x7f, 0x00, 0x01, 0x03, 0x00, 0x00, 0x00, 0x00, 0x42, 0x04, 0x00, 0x00, 0x48
2019-11-18 20:23:04.942 Detail, Node041,   ZW_SEND_DATA Request with callback ID 0x4e received (expected 0x4e)
2019-11-18 20:23:04.942 Info, Node041, Request RTT 1247 Average Request RTT 1437
2019-11-18 20:23:04.942 Detail,   Expected callbackId was received
2019-11-18 20:23:13.695 Error, Node041, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-11-18 20:23:13.696 Detail, Node041, Removing current message
2019-11-18 20:23:13.696 Detail, Node041, Notification: Notification - TimeOut
Any ideas, guys?
2 days of fighting and no results…
Found that issue at Github, anyone know the up-to-date version of openzwave we use at hassio?
May be i should just downgrade my Hass…
