Popular Moes thermostat not showing entities after ZHA pairing
Hope this is the right way to post this but here goes…
As mentioned by Stiltjack, I added this line into configuration.yaml:
zha:
  custom_quirks_path: /config/custom_zha_quirks/
Then saved the code beow as ts0601.py in the folder
Then a restart and it seemed to work.
"""Map from manufacturer to standard clusters for electric heating thermostats."""
"""Tuya MCU based thermostat."""
import logging
from zigpy.profiles import zha
import zigpy.types as t
from zigpy.zcl.clusters.general import Basic, Groups, Ota, Scenes, Time, GreenPowerProxy
from typing import Dict, Optional, Union
from zigpy.zcl import foundation
from zigpy.zcl.clusters.hvac import Thermostat
from zhaquirks.const import (
    DEVICE_TYPE,
    ENDPOINTS,
    INPUT_CLUSTERS,
    MODELS_INFO,
    OUTPUT_CLUSTERS,
    PROFILE_ID,
from zhaquirks.tuya import (
    TuyaManufClusterAttributes,
    TuyaThermostat,
    TuyaThermostatCluster,
    TuyaUserInterfaceCluster,
    NoManufacturerCluster,
    TUYA_MCU_COMMAND,
    TuyaLocalCluster,
from zhaquirks.tuya.mcu import (
    DPToAttributeMapping,
    TuyaClusterData,
    TuyaMCUCluster,
class TuyaTC(t.enum8):
    """Tuya thermostat commands."""
    OFF = 0x00
    ON = 0x01
class ZclTC(t.enum8):
    """ZCL thermostat commands."""
    OFF = 0x00
    ON = 0x01
TUYA2ZB_COMMANDS = {
    ZclTC.OFF: TuyaTC.OFF,
    ZclTC.ON: TuyaTC.ON,
MOESBHT6_TARGET_TEMP_ATTR = 0x0210  # [0,0,0,21] target room temp (degree)
MOESBHT6_TEMPERATURE_ATTR = 0x0218  # [0,0,0,200] current room temp (decidegree)
MOESBHT6_MODE_ATTR = 0x0402  # [0] manual [1] scheduled
MOESBHT6_ENABLED_ATTR = 0x0101  # [0] off [1] on
MOESBHT6_RUNNING_MODE_ATTR = 0x0424  # [1] idle [0] heating
MOESBHT6_RUNNING_STATE_ATTR = 0x0424  # [1] idle [0] heating
MOESBHT6_CHILD_LOCK_ATTR = 0x0128  # [0] unlocked [1] child-locked
_LOGGER = logging.getLogger(__name__)
class MoesBHT6ManufCluster(TuyaManufClusterAttributes, NoManufacturerCluster, TuyaLocalCluster):
    """Manufacturer Specific Cluster of some electric heating thermostats."""
    attributes = {
        MOESBHT6_TARGET_TEMP_ATTR: ("target_temperature", t.uint32_t, True),
        MOESBHT6_TEMPERATURE_ATTR: ("temperature", t.uint32_t, True),
        MOESBHT6_MODE_ATTR: ("system_mode", t.uint8_t, True),
        MOESBHT6_ENABLED_ATTR: ("enabled", t.uint8_t, True),
        MOESBHT6_RUNNING_MODE_ATTR: ("running_mode", t.uint8_t, True),
        MOESBHT6_RUNNING_STATE_ATTR: ("running_state", t.uint8_t, True),
        MOESBHT6_CHILD_LOCK_ATTR: ("child_lock", t.uint8_t, True),
    async def command(
        self,
        command_id: Union[foundation.GeneralCommand, int, t.uint8_t],
        *args,
        manufacturer: Optional[Union[int, t.uint16_t]] = None,
        expect_reply: bool = True,
        tsn: Optional[Union[int, t.uint8_t]] = None,
        """Override the default Cluster command."""
        # if manufacturer is None:
        #     manufacturer = self.endpoint.device.manufacturer
        self.debug(
            "Sending Tuya Cluster Command. Cluster Command is %x, Arguments are %s",
            command_id,
            args,
        # (on, off)
        if command_id in (0x0000, 0x0001):
            cluster_data = TuyaClusterData(
                endpoint_id=self.endpoint.endpoint_id,
                cluster_name=self.ep_attribute,
                cluster_attr="enabled",
                attr_value=TUYA2ZB_COMMANDS[command_id],  # convert tuya2zigbee command
                expect_reply=expect_reply,
                manufacturer=-1,
            self.endpoint.device.command_bus.listener_event(
                TUYA_MCU_COMMAND,
                cluster_data,
            return foundation.GENERAL_COMMANDS[
                foundation.GeneralCommand.Default_Response
            ].schema(command_id=command_id, status=foundation.Status.SUCCESS)
    def _update_attribute(self, attrid, value):
        super()._update_attribute(attrid, value)
        if attrid == MOESBHT6_TARGET_TEMP_ATTR:
            self.endpoint.device.thermostat_bus.listener_event(
                "temperature_change",
                "occupied_heating_setpoint",
                value * 100,  # degree to centidegree
        elif attrid == MOESBHT6_TEMPERATURE_ATTR:
                "local_temperature",
                value * 10,  # decidegree to centidegree
        elif attrid == MOESBHT6_MODE_ATTR:
            if value == 0:  # manual
                    "program_change", "manual"
            elif value == 1:  # scheduled
                    "program_change", "scheduled"
        elif attrid == MOESBHT6_ENABLED_ATTR:
            self.endpoint.device.thermostat_bus.listener_event("enabled_change", value)
        elif attrid == MOESBHT6_RUNNING_MODE_ATTR:
            self.endpoint.device.thermostat_bus.listener_event("running_change", value)
        elif attrid == MOESBHT6_RUNNING_STATE_ATTR:
        elif attrid == MOESBHT6_CHILD_LOCK_ATTR:
            self.endpoint.device.ui_bus.listener_event("child_lock_change", value)
class MoesBHT6Thermostat(TuyaThermostatCluster):
    """Thermostat cluster for some electric heating controllers."""
    def map_attribute(self, attribute, value):
        """Map standardized attribute value to dict of manufacturer values."""
        if attribute == "occupied_heating_setpoint":
            # centidegree to degree
            return {MOESBHT6_TARGET_TEMP_ATTR: round(value / 100)}
        if attribute == "system_mode":
            if value == self.SystemMode.Off:
                return {MOESBHT6_ENABLED_ATTR: 0}
            if value == self.SystemMode.Heat:
                return {MOESBHT6_ENABLED_ATTR: 1}
            self.error("Unsupported value for SystemMode")
        elif attribute == "programing_oper_mode":
            if value == self.ProgrammingOperationMode.Simple:
                return {MOESBHT6_MODE_ATTR: 0}
            if value == self.ProgrammingOperationMode.Schedule_programming_mode:
                return {MOESBHT6_MODE_ATTR: 1}
            self.error("Unsupported value for ProgrammingOperationMode")
        elif attribute == "running_state":
            if value == self.RunningState.Idle:
                return {MOESBHT6_RUNNING_STATE_ATTR: 1}
            if value == self.RunningState.Heat_State_On:
                return {MOESBHT6_RUNNING_STATE_ATTR: 0}
            self.error("Unsupported value for RunningState")
        elif attribute == "running_mode":
            if value == self.RunningMode.Off:
                return {MOESBHT6_RUNNING_MODE_ATTR: 1}
            if value == self.RunningMode.Heat:
                return {MOESBHT6_RUNNING_MODE_ATTR: 0}
            self.error("Unsupported value for RunningMode")
        return super().map_attribute(attribute, value)
    def program_change(self, mode):
        """Programming mode change."""
        if mode == "manual":
            value = self.ProgrammingOperationMode.Simple
        else:
            value = self.ProgrammingOperationMode.Schedule_programming_mode
        self._update_attribute(self.attributes_by_name["programing_oper_mode"].id, value)
    def enabled_change(self, value):
        """System mode change."""
        if value == 0:
            mode = self.SystemMode.Off
        else:
            mode = self.SystemMode.Heat
        self._update_attribute(self.attributes_by_name["system_mode"].id, mode)
    def running_change(self, value):
        """Running state change."""
        if value == 0:
            mode = self.RunningMode.Heat
            state = self.RunningState.Heat_State_On
        else:
            mode = self.RunningMode.Off
            state = self.RunningState.Idle
        self._update_attribute(self.attributes_by_name["running_mode"].id, mode)
        self._update_attribute(self.attributes_by_name["running_state"].id, state)
class MoesBHT6UserInterface(TuyaUserInterfaceCluster):
    """HVAC User interface cluster for tuya electric heating thermostats."""
    _CHILD_LOCK_ATTR = MOESBHT6_CHILD_LOCK_ATTR
class MoesBHT6(TuyaThermostat):
    """Tuya thermostat for devices like the Moes BHT-006GBZB Electric floor heating."""
    signature = {
        MODELS_INFO: [
            ("_TZE204_aoclfnxz", "TS0601"),
        ENDPOINTS: {
			#  endpoint=1 profile=260 device_type=81 device_version=1 input_clusters=[0, 4, 5, 61184],
			#  output_clusters=[10, 25]
            1: {
                PROFILE_ID: zha.PROFILE_ID,
                DEVICE_TYPE: zha.DeviceType.SMART_PLUG,
                INPUT_CLUSTERS: [
                    Basic.cluster_id,
                    Groups.cluster_id,
                    Scenes.cluster_id,
                    TuyaManufClusterAttributes.cluster_id,
                OUTPUT_CLUSTERS: [Time.cluster_id, Ota.cluster_id],
			242:{
                PROFILE_ID: 41440,
                DEVICE_TYPE: 97,
                INPUT_CLUSTERS: [],
                OUTPUT_CLUSTERS: [GreenPowerProxy.cluster_id],
    replacement = {
        ENDPOINTS: {
            1: {
                DEVICE_TYPE: zha.DeviceType.THERMOSTAT,
                INPUT_CLUSTERS: [
                    Basic.cluster_id,
                    Groups.cluster_id,
                    Scenes.cluster_id,
                    MoesBHT6ManufCluster,
                    MoesBHT6Thermostat,
                    MoesBHT6UserInterface,
            242: {
                PROFILE_ID: 41440,
                DEVICE_TYPE: 97,
                INPUT_CLUSTERS: [],
