Do we have any options to Populate and/or update a To-Do list via Node Red?
I’d like to monitor my Battery powered sensors and populate a To-Do list via NodeRed.
To-Do List is a base integration for other integrations to use.
In HA the lists can be shown using a To Do list card.
The list entity state is the count of uncompleted item on the list.
There are a range of service calls provided that can be called from HA or by using the HA WebSocket service call node in Node-RED.
https://www.home-assistant.io/integrations/todo/#services
As will be the way going forward, there are no attributes to a To Do List entity - the actual current list is obtained by performing the service call To-do list: Get to-do list items. The version of HA WebSocket nodes I am currently using does not support service call returns, so I am waiting for the next Node-RED addon release, which should include Node-RED v3.1.1 and the latest WebSocket node version. Hopefully then service call return values will become available and it should be possible to get a to-do list back into Node-RED.
You can get the current items from the todo list by using the API node. You need to set data up like this:
msg.payload.data = {
"type": "execute_script",
"sequence": [
"service" : "todo.get_items",
"target" : {
"entity_id" : entity
"data" : {
"status" : status
"response_variable" : "service_result"
"stop" : "done",
"response_variable": "service_result"
‘entity’ being the todo list entity and status being either ‘completed’ or ‘needs_action’. Status can be left blank if you want both.
