This posting has a VERY useful way to display in a custom card all Alexa Timers that have been set.
I’m trying to capitalize on this work and populate 6 entities in HOME ASSISTANT that can then be used to trigger other automations and update a display showing 3 Alexa timers in OpenHASP.
Its too bad the integration doesn’t support the single biggest use case for Alexa. Setting timers and Alarms.
The code loads WITHOUT the section populating the entities. Lovelace is tough… I’m not seeing any errors anywhere, but when we add the stuff for the sensors, it won’t load the card. How on earth do you debug this .js stuff in Lovelace???
if(this.alarms.length > 0) {
this.innerHTML = `
<ha-card header="Echo Timers" class="alexa-timers">
<div class="card-content"></div>
</ha-card>
this.content = this.querySelector('div');
let table = "<table border='0' width='100%'>";
for(let i = 0; i < this.alarms.length; i++) {
let name = this.alarms[i].label;
if(name === null) {
name = getNameFromDuration(this.alarms[i].originalDurationInMillis);
let timeLeft = this.alarms[i].hours + ":" + addLeadingZero(this.alarms[i].minutes) + ":" + addLeadingZero(this.alarms[i].seconds);
table += "<tr>";
table += "<td>" + name + "</td>";
table += "<td>" + timeLeft + "</td>";
table += "</tr>";
//add populating the first 3 timers into HA entities ***DOES NOT WORK - why????***
if(i == 0) {
this.hass.states[input_text.alexa_timer_0_name] = name;
this.hass.states[input_number.alexa_timer_0_timeleft] = timeLeft;
if(i == 1) {
this.hass.states[input_text.alexa_timer_1_name] = name;
this.hass.states[input_number.alexa_timer_1_timeleft] = timeLeft;
if(i == 2) {
this.hass.states[input_text.alexa_timer_2_name] = name;
this.hass.states[input_number.alexa_timer_2_timeleft] = timeLeft;
table += "</table>";
this.content.innerHTML = table;
I have created all 6 entities in HA
Help!
