I have a question on the population of values to templates
I have a sensor that spikes for no reason sometimes to -40, i do not want these spikes in the database or in a graph.
In Lovelace I have now displayed both values as badges but the sensor (sensor.new_wp_buitentemp) that get’s filled when the IF is true, the strange thing is that the template is populated once every few minutes(not a fixed period), the original sensor('sensor.wp_buitentemp) is populated every few seconds.
does anyone understand what and/or why this is happening ? and perhaps how to fix this.
same behavior in the Template editor.
Not a direct answer to your question, but spikes can be filtered out by using a filter sensor. You then use the filter sensor in place of the actual sensor. https://www.home-assistant.io/integrations/filter/
Hi Thomas
I have tried this but as the sensor has a big range I have not got the filter correct.
i have rewritten the sensor and this is working as quick as i would epected
i don’t understand why this would be different.
