First I got only a single point of url up and running using DuckDNS, everything worked flawlessly. Then I came up with the idea to use http at local network and https externally using duckpins + nginx. After configured nginx for the first time it started without any problems. The problem occurred after I rebooted HA for the first time after installed nginx. It won’t start after the reboot and says port 443 and 80 are both used.
System info:
Home Assistant 2023.2.3
Supervisor 2023.01.1
Operating System 9.5
Here is what I tried:
- I’ve stopped all addons even rebooted and tried to start nginx as the only add-on → still the same error
- I logged into ssh and did netstat which leads me to no clue. (Yes I used “sudo” as well)
➜ ~ sudo netstat -anpe | grep "443" | grep "LISTEN"
tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 0 10087 -
tcp6 0 0 :::443 :::* LISTEN 0 14402 -
➜ sudo netstat -anpe | grep "80" | grep "LISTEN"
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 0 12771 -
tcp6 0 0 :::80 :::* LISTEN 0 12776 -
- What I also tried was to call “http://my-home-assistant-ip” to see if any Webserver would come up → no
I googled a lot and did my search for several days and still found no solution. Any idea/help is appreciated! Thanks!
