I’ve install ESPHome to my Synology NAS via container esphome/esphome.
Added first device (ESP8266+AM2320). Configuration:
esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid: "MikroTik"
password: "wifipassword"
ap:
ssid: "Node1 Fallback Hotspot"
password: "ZhEguJSj7JY3"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
password: 'welcome'
port: 6053
ota:
- platform: dht
pin: D2
temperature:
name: "Living room temperature"
humidity:
name: "Living room humidity"
model: AM2302
# model: AUTO_DETECT
update_interval: 15s
#sensor:
# - platform: dht
# pin: D2
# temperature:
# name: "Living Room Temperature"
# humidity:
# name: "Living Room Humidity"
# update_interval: 30s
#remote_receiver:
# pin: D2
# dump: all
Now I’m experiencing troubles to add esphome to my HA.
When I trying to add HA write message:
Can’t connect to ESP. Please make sure your YAML file contains an ‘api:’ line.
I checked netstat in container:
root@esphome-esphome1:/config# netstat -ln
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State
tcp 0 0 0.0.0.0:6052 0.0.0.0:* LISTEN
tcp6 0 0 :::6052 :::* LISTEN
udp 0 0 0.0.0.0:8472 0.0.0.0:*
udp 1536 0 0.0.0.0:5353 0.0.0.0:*
udp 0 0 0.0.0.0:5353 0.0.0.0:*
Active UNIX domain sockets (only servers)
Proto RefCnt Flags Type State I-Node Path
HA looking for 192.168.1.5:6053, but nothing listening port.
Howto start api interface of ESPHome?
Or, maybe, I dont understand mechanism? Or doing something wrong?
Thanks for any help.
