Config: node-red-contrib-amazon-echo running on Home Assistant Core 0.115.6 (Synology Native Package)
I am trying to get Amazon local working with the node-red-contrib-amazon-echo add-on (added via pallets). It is looking to bind to port 80, however, Synology is already using port 80 for other services.
How have folks gotten around Node Red with Amazon Local wanting to be on port 80 when its needed by Synology? I’ve not been able to find any other post on the matter, which leads me to believe I’m doing something wrong. Should I be running a different Node Red pallet?
awesome, thank you! I will look at that now. I’ve about decided to just move HA off onto its own pc.
So its using the ngix to redirect port80 traffic to your chosen port for the synology.
Cheers
