Is all communication to Home Assistant including sensor update from HAss App going via the same port 8123? Or can be sensor update from HAss App be do in a different way?
Currently I am running HAss in my LAN with no access from outside. I have an own domain, running a proxy server for other applications and I am running a VPN. I can reach HAss from HAss App on the phone when I enable VPN. That is fine for my use case. Technically I am also able to set-up the reverse proxy or port forwarding to permanently get access from outside. This I have not done so far due to security concerns.
My issue is that I would like to open the connection for the HAss App to update the position data without exposeing my full HAss to the outside world. Any possibilities?
The only options I see so far:
- permanently enable VPN on the mobile
- expose full HAss to outside by port forwarding in the firewall
- expose full HAss to outside by reverse proxy
