After installation via docker on qnap and start I periodically get
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 130, in async_init
result = await self._async_handle_step(
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 213, in _async_handle_step
result: Dict = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/daikin/config_flow.py", line 138, in async_step_zeroconf
devices = Discovery().poll(ip=discovery_info[CONF_HOST])
File "/usr/local/lib/python3.8/site-packages/pydaikin/discovery.py", line 52, in __init__
sock.bind(("", UDP_SRC_PORT))
OSError: [Errno 98] Address in use
Same what I found here and should be corrected there.
https://github.com/home-assistant/netdisco/issues/216
Any hints, why this occurs compared to the link?
