Portainer Network Connection
So, i made a complete mess of things.
I was messing around with Portainer on hass.io and while attempting to "Fix"the network connectivity to my new docker container, i appear to have broken my connectivity to Home Assistant altogether.
I had just created a new network connection in Portainer and accidentally set it to the same subnet of Home Assistant.
Now i am unable to access HA via the web interface. I do still have access to the physical terminal for entering commands.
Any ideas on how i can undo my blunder?
You are going to have to be very careful here.
the Docker documents are here for networks;
Point to note that this is more of a docker question than an HA one. you may get a more detailed response from their forums;
I hope that it helps you along the way?
Also post your platform: Pi, Ubuntu with docker, VM etc.
Thank you for the feedback. Sorry for the low details.
Proxmox Host
HassOS 3.5
0.103.6.
I think i have found the network connection i created within the docker environment.
Fingers crossed this works!
Most importantly backup before you do anything!!
In my excitement and haste, i forgot to report back.
I have regained access to HA by deleting the network connection i create. Panic over!
Thanks for pointing me in the right direction.
You are welcome - glad it’s sorted now.
I’m in the same boat.
How have you deleted it?
I don’t really have a micro-hdmi to edit using docker, in place
I’m trying thing thing where I’d use boltbrowser and strings to mess around /sda8/docker/network/files/ and delete some entries in there. Not yet sure if it’s going to work – or if I messed up docker somehow.
UPDATE: … after about 45 minute (and another 2 hours remaining to write out my sd card, I decided it’s been a while since I ran choco update all and process got interrupted. So I gave up, I’ll restore from last nights snapshot.
