Position of 2 vertical stacks
title: "Home"
path: "home"
cards:
  - type: horizontal-stack
    cards:
      - type: vertical-stack
        view_layout:
          # position: left
          width: 33%  # 1/3 van de breedte
        cards:
          - type: "custom:stack-in-card"
            cards:
              - type: custom:mushroom-entity-card
        view_layout:
          # position: right
          width: 66%
        cards:
gives me this result…
how do I remove the white zone left and right ?
Where did “view_layout” come from? I don’t see it in the vertical stack docs.
Having said that, panel view will expand the columns to fill the screen.
hmm. when I use type:panel I get unknown type encountered: panel
title: "Home"
path: "home"
panel: true # !!!!!!!!!!!!!!!
cards:
wow, that simpel :slight_smile:
and how can I make my first column smaller ?
Please do mark a post of Jack as a solution, technically they proposed a panel layout ).
To make a column smaller: go to main card-mod thread → 1st post → link at the bottom titled “fantastic post” → styles for horiz stack
type: custom:mod-card
card_mod:
  style:
    hui-horizontal-stack-card $: |
      div#root > :first-child > * {
        width: 30%;
        flex: auto;
      div#root > :last-child > * {
        width: 70%;
        flex: auto;
card:
like this ?
May be if you took it from my post, cannot check.
i took it from here : 🔹 Card-mod - Add css styles to any lovelace card - #1731 by Ildar_Gabdullin?
title: "Home"
path: "home"
panel: true
cards:
  card_mod:
    style:
          width: 30%;
          flex: auto;
          width: 70%;
          flex: auto;
  card:
      cards:
but I get a white screen …
Compare your 2 codes from this & prev posts, they are different, the latest is wrong.
title: "Home"
path: "home"
panel: true
cards:
  - type: custom:mod-card
    card_mod:
      style:
            width: 20%;
            flex: auto;
            width: 80%;
            flex: auto;
    card:
      cards:
          cards:
          style: |
            ha-card {
              margin-top: 170px;
          card:
            type: conditional
            conditions:
              - entity: input_select.dashboard_view
                state: 'verlichting'
            card:
              cards:
                  cards:
i still got a lot of white space between “the menu” and the stuff right …
