Positioning lvgl Widgets
I’m trying to come up with a base configuration to use as template for other projects. The included code produces what’s shown in the image. This is running on a 4.3" Waveshare display.
I have the outlines turned on so I can see where everything is positioned.
My questions are:
  • Why do the Day/Date labels at the top and the Prev/Next buttons at the bottom seems to extend off the display.
  • How do I get the text and icons centered vertically in the Labels.
I’ve tried all the variations for “align” and “text_align” but nothing seems to change the position. It’s always at the top.
substitutions:
  friendly_name: Test Display
esphome:
  friendly_name: ${friendly_name}
  name_add_mac_suffix: false
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: esp-idf
    sdkconfig_options:
      CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: y
      CONFIG_ESP32S3_DATA_CACHE_64KB: y
      CONFIG_SPIRAM_FETCH_INSTRUCTIONS: y
      CONFIG_SPIRAM_RODATA: y
# Enable logging
logger:
  logs:
    component: ERROR
# Enable Home Assistant API
api:
  encryption:
    key: !secret haapi_key
ota:
  - platform: esphome
    password: !secret ota_password
wifi:
  ssid: !secret wifi_ssid
  manual_ip:
    static_ip: 10.0.0.230
    gateway: 10.0.0.1
    subnet: 255.255.255.0
    dns1: 75.75.75.75
    dns2: 75.75.76.76
  fast_connect: off
#  ap:
#    ssid: "${friendly_name} Fallback"
#    password: !secret haapi_password
#web_server:
#captive_portal:
psram:
  mode: octal
  speed: 80MHz
i2c:
  - id: i2cbus_a
    sda: GPIO08
    scl: GPIO09
    scan: True
ch422g:
  - i2c_id: i2cbus_a
switch:
  - platform: restart
  - platform: gpio
    name: ${friendly_name} Backlight
    pin:
      ch422g: ch422g_hub
      number: 2
      allow_other_uses: true
      mode:
        output: true
    inverted: false
    restore_mode: ALWAYS_ON
- platform: wifi_signal
  name: "${friendly_name} Signal Strength"
  update_interval: 60s
text_sensor:
- platform: wifi_info
  ip_address:
  ssid:
  bssid:
  mac_address:
time:
  - platform: homeassistant
    on_time_sync:
      - script.execute: time_update
      - script.execute: date_update
    on_time:
      - minutes: '*'
        seconds: 0
        then:
      - hours: 0
        minutes: 0
        seconds: 0
        then:
display:
  - platform: rpi_dpi_rgb
    auto_clear_enabled: false
    update_interval: never
    color_order: RGB
    pclk_frequency: 16MHz
    dimensions:
      width: 800
      height: 480
    reset_pin:
      ch422g: ch422g_hub
      number: 3
    enable_pin:
      ch422g: ch422g_hub
      number: 2
    de_pin:
      number: 5
    hsync_pin:
      number: 46
      ignore_strapping_warning: true
    vsync_pin:
      number: 3
    pclk_pin: 7
    pclk_inverted: false
    hsync_back_porch: 10 #30
    hsync_front_porch: 20 #210
    hsync_pulse_width: 10 #30
    vsync_back_porch: 10 #4
    vsync_front_porch: 10 #4
    vsync_pulse_width: 10 #4
    data_pins:
      red:
        - 1         #r3
        - 2         #r4
        - 42        #r5
        - 41        #r6
        - 40        #r7
      blue:
        - 14        #b3
        - 38        #b4
        - 18        #b5
        - 17        #b6
        - 10        #b7
      green:
        - 39        #g2
        - 0         #g3
        - 45        #g4
        - 48        #g5
        - 47        #g6
        - 21        #g7
touchscreen:
  platform: gt911
  address: 0x5D
  i2c_id: i2cbus_a
  update_interval: 16ms
  interrupt_pin: GPIO4
  reset_pin:
    ch422g: ch422g_hub
    number: 1
    mode: output
  on_touch:
    - switch.turn_on: backlight_switch
    - lvgl.resume:
    - lvgl.widget.redraw:
    - lambda: |-
          ESP_LOGI("cal", "x=%d, y=%d, x_raw=%d, y_raw=%0d",
              touch.x,
              touch.y,
              touch.x_raw,
              touch.y_raw
lvgl:
  displays:
    - my_display
  buffer_size: 25%
  disp_bg_color: 0x000000
  touchscreens:
    - touchscreen_id: my_touchscreen
  style_definitions:
    - id: header_footer
      align: CENTER
      text_align: CENTER
      bg_color: 0x000000
      bg_opa: COVER
      border_opa: TRANSP
      radius: 0
      pad_all: 0
      pad_row: 0
      pad_column: 0
      outline_color: 0xA17716
      outline_width: 2
      text_font: montserrat_28
      border_color: 0x000000
      text_color: 0x323AA8
      width: 90%
      height: 50
    - id: time_format
      bg_color: 0x000000
      bg_opa: COVER
      border_opa: TRANSP
      grid_cell_x_align: Stretch
      grid_cell_y_align: CENTER
      outline_color: 0xFFFF00
      outline_width: 2
      text_align: CENTER
      align: CENTER
      text_font: montserrat_48
      width: 90%
      height: 90%
    - id: footer_button
      width: 30%
      bg_opa: TRANSP
      border_opa: TRANSP
      shadow_opa: TRANSP
      pad_all: 0
      outline_color: 0x00FF00
      outline_width: 2
  top_layer:
    widgets:
      - label:
          styles: header_footer
          text: "JAN 22"
          align: top_right
          width: 45%
      - label:
          text: "MON"
          align: top_left
          width: 45%
      - button:
          styles: footer_button
          align: bottom_left
          on_press:
            then:
              lvgl.page.previous:
          widgets:
            - label:
                text: "\uF053"
      - button:
          align: bottom_mid
          on_press:
            then:
              lvgl.page.show: main_page
          widgets:
            - label:
                text: "\uF015"
      - button:
          align: bottom_right
          on_press:
            then:
              lvgl.page.next:
          widgets:
            - label:
                text: "\uF054"
  pages:
    - id: main_page
      bg_color: 0x000000
      widgets:
        - obj:
            align: CENTER
            width: 770
            height: 370
            bg_opa: TRANSP
            border_opa: TRANSP
            outline_width: 2
            outline_color: 0xFF0000
            layout:
              type: grid
              grid_columns: [FR(1)]
              grid_rows: [FR(1)]
            widgets:
              - label:
                  grid_cell_column_pos: 0
                  grid_cell_row_pos: 0
                  text: "--:--"
                  styles: time_format
script:
# This script updates the time
#            snprintf(time_buf, sizeof(time_buf), "%2d:%02d%s", hour_12, now.minute, is_pm ? "pm" : "am"); // This does have the ap/pm flag
  - id: time_update
    then:
      - lvgl.label.update:
          id:
            - display_time
          text: !lambda |-
            static char time_buf[17];
            auto now = id(esptime).now();
            bool is_pm = now.hour >= 12;
            int hour_12 = now.hour % 12;
            if (hour_12 == 0) {
                hour_12 = 12;
            snprintf(time_buf, sizeof(time_buf), "%2d:%02d", hour_12, now.minute); // This does NOT have the ap/pm flag
            return time_buf;
#This script updates the Day and Date
  - id: date_update
    then:
          id:
            - date_label
          text: !lambda |-
            static const char * const mon_names[] = {"JAN", "FEB", "MAR", "APR", "MAY", "JUN", "JUL", "AUG", "SEP", "OCT", "NOV", "DEC"};
            static char date_buf[8];
            snprintf(date_buf, sizeof(date_buf), "%s %2d", mon_names[now.month-1], now.day_of_month);
            return date_buf;
          id:
            -  day_label
          text: !lambda |-
            static const char * const day_names[] = {"SUN", "MON", "TUE", "WED", "THU", "FRI", "SAT"};
            return day_names[id(esptime).now().day_of_week - 1];
