As far as I know, you can’t create sensors from the GUI currently.
I only see the Doppel-S (double S) how we call it in Switzerland in the friendly name not in the entity_id, so there should be no issue.
Hi, yes, I already saw it… but I am still getting an error and I am not yet sure, if (or better where) I’ve made a mistake…
Did you restart HA? Can you please post the error?
Okay, So here we go with a “vanilla yaml version”
To make it clear,I don’t have covers and don’t plan on having any soon but …
With gracious thanks to : -
@febalci @pedrorferreira for the inputs and @Burningstone just for his usual support
@Joca - I don’t use scenes, I use scripts for the equivalent, but thanks anyway
I have put the following together, please point out any mistakes
(I don’t have covers - so can’t test at all ) and I’ll correct them so that anyone coming across it doesn’t get side-swiped. (This is written for a package so cut and paste snippets if you don’t use them).
sensors:
s_cover_bed1_position:
friendly_name: Bed 1 Cover Position
value_template: "{{ state_attr(‘cover.bed1_cover’, ‘current_position’) }}"
icon_template: >
{% set posn = state_attr(‘cover.bed1_cover’, ‘current_position’) | int %}
{% if posn == 0 %}
mdi:window-shutter
{% elif posn == 100 %}
mdi:window-shutter-open
{% else %}
mdi:window-shutter-alert
{% endif %}
input_datetime:
id_cover_bed1_open:
name: Bed1 Cover Opens At
has_time: true
icon: mdi:clock-start
id_cover_bed1_close:
name: Bed1 Cover Closes At
has_time: true
icon: mdi:clock-end
input_number:
in_cover_bed1_posn_ctrl:
name: Bed 1 Position Control
min: 0
max: 100
step: 1
mode: slider
icon: mdi:rotate-right
automation:
- alias: au_cover_bed1_posn_ctrl
- platform: state
entity_id: input_number.in_cover_bed1_posn_ctrl
- service: cover.set_cover_position
data_template:
entity_id: cover.bed1_cover
position: "{{ states('input_number.in_cover_bed1_posn_ctrl') | int }}"
- alias: au_cover_bed1_open
value_template: "{{ states('sensor.time') == states('input_datetime.id_cover_bed1_open') [0:5] }}"
- service: input_number.set_value
value: 90
- alias: au_cover_bed1_close
value_template: "{{ states('sensor.time') == states('input_datetime.id_cover_bed1_close') [0:5] }}"
value: 0
The above requires sensor.time to have been set up
I’ve put some sample automations in (for time activation too) feel free to adapt
Two possible issues : -
I hate having to build stuff like this without an actual device to work from, so this ‘may’ be my first and last attempt at doing so…
I swear no edits until someone feeds back a mistake (there’s bound to be at least one)
Sorry if this isn’t prudent. I am new at this.
I am trying to create a card that shows the current position of a blind/cover using svg icons (open / 25 / 50 / 75 / closed), so that it animates when opening and closing, plus showing a decently accurate representation of how low the cover is at any moment. The generic icons for open / close is just boring, but what I want to do seems terribly difficult to achieve.
I have read many threads that touch upon it but none that give a complete explanation, so that we who are codeally challenged might understand. Do I have to create a sensor, or a sensor template, or an input_select? Why is it that the entity card can show the attribute current_position, but I cant get that in any other card, like cust button card – let alone actually use the value?
Keeping fingers crossed for some hallelujah answer!
I am using this card to animate the blinds. Maybe the code could help you
