I think I might have discovered a possible bug in the Daikin integration.
Below is the YAML for the automation (I removed some device_id’s just to make it a bit easier to read):
alias: Climate - Turn Living Room AC - Heat
description: Turns off AC after a period of inactivity
- type: no_motion
platform: device
entity_id: binary_sensor.living_room_motion_sensor
domain: binary_sensor
for:
hours: 0
minutes: 15
seconds: 0
milliseconds: 0
condition:
- condition: device
type: is_off
entity_id: remote.my_condo
domain: remote
for:
hours: 0
minutes: 10
seconds: 0
milliseconds: 0
- condition: device
domain: climate
entity_id: climate.living_room_ac
type: is_hvac_mode
hvac_mode: heat
domain: climate
type: set_hvac_mode
hvac_mode: 'off'
mode: single
Explanation of the automation and desired result:
When my Daikin AC unit is heating, and there has been a period of inactivity by both my Harmony hub (My condo) and no motion by the motion sensor, turn off the AC unit.
I’ve troubleshoot (troubleshot?) this by lowering the period of inactivity to 5 seconds and removing the conditions of the Harmony hub, and AC unit altogether and the automation worked. It turned off exactly as expected.
The problem
This Daikin AC unit is both a heater and a traditional AC unit that blows cold air. Its also a fan and I believe a dehumidifier. So the state or condition of what mode the unit is in is important. I would like a similar automation to work during the summer when the unit’s HVAC mode is set to ‘cool’.
I’ve checked the state of the AC unit via the developer tools when its set to heat and it shows up as ‘heat’. See below:
However it doesn’t seem to work within the automation. I’ve tried both using the ‘State’ as a condition in regard to its HVAC Mode:
condition: state
state: heat
attribute: hvac_modes
and ‘Device’:
condition: state
state: heat
neither worked.
SUCCESS?!
However, after several different tweaks to the automation, I got it to work using this Condition:
condition: state
state: heat
I had to remove HVAC mode as an attribute. Which I found a bit counter-intuitive and without a doubt the source of my frustration over the past few days for me. And using ‘Device’ as a condition I believe you have to using some underlying mode or preset. (I could be wrong in this regard. After I got it working with the ‘State’ without an HVAC mode, I didn’t test ‘Device’ without any preset selected.)
Am I reading the developer tools wrong? Can someone explain what exactly is going on here? Is this a bug or something else?
I hope this is helpful for someone and thanks in advance.
