Just starting to add some new functionality to my “summer/winter” mode in Home Assistant and created a new input.boolean to be able to control the summer/winter state using my calendar. Have done similar in other areas.
Having created the helper, it has no edit pane if I select edit, just coming up with a blank edit header:
so I can’t either go back and change default behaviours, naming, etc. or the area it is associated with.
I have a number of other toggles which I setup month back and, from memory, these could all be edited without issue (but no longer). I have many other helpers, all of which do allow editing.
I’m assuming this is a bug in 2026.9.2
Running on latest everything on Home Assistant Green.
