Possible hysteresis in On/Off Automation Option
Hello dear,
To avoid continuos switch on / off with the Room Temperature Threshold variable , it is possible to insert a calibratable hysteresis on this threshold?
Thank you!
Franco
Iā€™m not exactly sure what you are referring when you say this, but if you have a temperature sensor as the input for a threshold sensor, you can configure a hysteresis value. Then you would use the threshold sensor instead of your raw temperature sensor as the trigger to your automation to prevent continuous switching on/off.
