I’m new in this forum but am running home-assistant for about one year now.
I’ve just upgraded to version 2021.1.5 and spotted what seems to be an issue in the CSS code of the media_play card.
I’m using a custom theme (derived from ‘Google - Dark’) and noticed that I had a contrast issue between my definition of ‘primary-color’ and the ‘primary-background-color’.
I’ve changed ‘primary-color’ into a lighter value to solve this issue.
However, as a side effect, my media_player cards became lighter than the other cards in lovelace display.
I’ve investigated the html entities styling and noticed that ‘color-block’, ‘image’ and ‘no-img’ classes for the media_player card used the ‘primary-color’ value as background color whereas all the other cards seem to use the ‘ha-card-background’ color value.
The following patch seems to solve the issue:
[homeassistant@appart frontend_latest] diff -u chunk.9a230f4e1ba6d82a8c78.js.ori chunk.9a230f4e1ba6d82a8c78.js
--- chunk.9a230f4e1ba6d82a8c78.js.ori 2021-01-24 22:07:08.808832410 +0100
+++ chunk.9a230f4e1ba6d82a8c78.js 2021-01-24 22:09:33.296293501 +0100
@@ -152,7 +152,7 @@
.color-block {
- background-color: var(--primary-color);
+ background-color: var(--ha-card-background);
transition: background-color 0.8s;
width: 100%;
@@ -161,7 +161,7 @@
position: absolute;
background-image: linear-gradient(
to right,
- var(--primary-color),
+ var(--ha-card-background),
transparent
height: 100%;
@@ -171,7 +171,7 @@
.image {
background-position: center;
background-size: cover;
background-repeat: no-repeat;
@@ -188,7 +188,7 @@
.no-img {
background-size: initial;
background-position: center center;
Could somebody let me know if my analysis makes sense and if it is worthy of opening an issue?
Thanks!
