I got many ESP32 with Espresense installed for Temp/Hum and Trackers - one device per rooms of my house. All esp32 device are hidden above ceiling with Temperature and Humidity Sensor mount at the ceiling.
thinking of adding all existing esp32 to ESPHome and can modify via Wi-Fi and able to upgrade firmware version.
How to do that - got all esp device’s MAC address and their fitted IP address - does that help, I hope ? cos I don’t want to digging floorboards up to reprogramming esp with usb. :-/
oh right ok, is there replacement same setup what i used at moment to setup new ESPHome from scratch? Any guide to help with code for ESPHome?
need setup for Temp & Hum and Bluetooth trackers that linked to my Home Assistant vis MQTT.
i will get new esp32 and test on it to start with before i do furthers all rooms in my house. Where do i start? help would be nice… i am still learning.
ESPresense already web support and easy to amendment through there.
I used espresence for quite a while and im now using Bermuda and so far, its works just as good or possibly better and just needs BT proxy installed on esp32.
Espresence is its own firmware like esphome is its own firmware and the two dont quite get along. I would only suggest that you try both and see what you think.
I have shelly mini gen3 devices and wanted to use them for locating my apple watch in different rooms. I preferred bermuda, because it should work with shelly without flashing with espresence, but I am not sure, if I can locate my watch in different rooms and use that nice room map from espresence (see Companion | ESPresense).
Is a room map possible in bermuda?
