Possible To Automate Muting or Do Not Disturb on Echo / Alexa devices from HA?
From what I’ve read there’s no way to remotely send the mute command or Do Not Disturb to Echo / Alexa devices. Is this correct?
After having some guests over last night, I was thinking how great it would be to disable the audio commands on Echo / Alexa devices since with that many people having fun, it can quickly get out of hand. :slight_smile:
Any clever ideas or suggestions using Home Assistant? Maybe thinking “guest mode” could disable the network connection to those devices or something as a workaround…
The only option I found so far is to set each alexa on a different wifi network and disable the network via unifi api or block the internet for that device from the router… The “ugly” solution would be a servo and a color sensor to get state…
