Possible to change color of sensor data if increasing/decreasing from previous value?
I am monitoring a group of 20 temperature sensors and would like to display if each temp is either increasing or decreasing in color, similar to what is found on a stock ticker.
I know I can change the style using the card_mod HACS integration, but I don’t know if there’s a CSS interpretation that monitors a value change.
Does anyone know of a solution?
I believe the statistics sensor displays the trend, so I guess create a sum of all of them and add this to the statistics sensor.
Thank you, I think I’m halfway there. I created a statistics helper to monitor the last 2 sensor values and have the positive/negative result. Next step is to add that to the card_mod CSS styling as an if statement for color style on whether positive/negative.
I’m stuck now trying to figure out how card_mod can take the value of a one sensor and applying the style to a different one.
Simply substituting the newly created ‘sensor.temp_office_trend’ for ‘states(config.entity)’ unfortunately does not work.
  - entity: sensor.central_office_temperature
    card_mod:
      style: |
        :host {
          color:
            {% if states(sensor.temp_office_trend) | int < 0 %} red {% endif %};
Suggest to test templates in “Dev tools → Template”, here the template is wrong (quotes missing).
Btw if the condition is “false” you will get
color: ;
which is an error in css.
Thank you! I just needed to add the quotes! (I do have another condition for green but left it out above for simplicity :slight_smile:
    card_mod:
      style: |
        :host {
          color:
            {% if "states(sensor.temp_office_trend) | int < 0" %} red
            {% elif "states(sensor.temp_office_trend) | int >= 0" %} green
            {% endif %};
EDIT: The quotes are incorrect.
states(‘sensor.temp_office_trend’) is the correct format (thank you Ildar)
The above code correctly outputs:
Ideally only the actual temperature would change color and not the label. I tried the below but it’s not applying to the card.
    card_mod:
      style:
        hui-generic-entity-row:
            text-content:not(.info) {
              color:
                {% endif %};
No, the template is wrong.
You think that it is correct because
is same as
if "any string"
which gives “true”.
Must be
if states('sensor.temp_office_trend') | int < 0
Thank you again!
Changing the quotes to the “hui-generic-entity-row” style did not change the output.
I tried the below in the card after seeing the correct output in Dev Tools and it doesn’t change the color of the value. Is “text-content:not(.info)” the incorrect parameter?
    card_mod:
      style:
              color:
                green
I am not getting, I told about quotes for the template, not for the “hui-generic-entity-row” word.
Suggest to go to the main card-mod thread, check the 1st post → link at the bottom titled “fantastic” and then ask ANY card-mod-related questions THERE.
Apologies for not being specific. I was using your advice to also change the quotes to my previous post above your reply/correction. I’m attempting to change just the color of the value returned (data) and not the text.
Yes, and this example & many other examples are explained in that path I mentioned above. Suggest to check it, might be educative & useful.
I’ve been reading the posts! You’ve been very busy :grinning:
Thank you for all your work and leading me to this excellent treasure trove!
