Possible to change icon in device_tracker on the map?
Hi, I hope you can help me, do you know how I can change the icon inside the map of my device_tracker?
When I try to modify it, it does not change on the map but only the entity.
Thank you and sorry for my writing if it’s not quite right!
Not sure you can use an icon but you can use a picture with entity_picture
Change it in Customizations section
Can you please help me to put the image I don’t know how to put it I am already in “customisations” but that field does not appear.
After doing this, it still doesn’t appear, although I don’t know if I did it right.
Solved, thank you very much. The last thing didn’t work because the photo wasn’t in the right place.
Thank you!
OK no problem
